Realtek HD and P5N-D Microphone problem
Tetsuya
1:51 AM
Hello, i searched this forum for an answer but i didn't find any.
I run on Seven build 7000 but i can't get my microphone to work =s
I updated my Realtek drivers to R2.16 but nothing works.
My microphone is detected but it does not work, i tried to plug it on the front and rear.
I'm a little stuck and any help would be appreciated =p
Thank you =)
Seven
Seven
Hi Tetsuya, i have this motherboard with build 7000 x64 Realtek HD audo drivers 6.0.1.5791 with similar problems. Open up realtek and choose mic. click on microphone boost and crank it up to +30.0 db. That fixed my problem with mic and i use Teamspeak, Skype and Xfire, but i could only get the headset to put out sound. I tried pluging in speakers to all of the outputs with no luck. Give me more specifics about your system and i will try to assist future.
windows 7 betaE8400 C2DOCZ ddr2-800 4 1gb sticksMSI 260gtx
Custom built by me
windows 7 beta
E8400 C2D
Asus p5k-vm
MSI 260gtx
24" Sceptre LCD
1920 x 1200
Western Digital 80gb sata C140D5F
Raidmax 850watt RX-850SS
Tagan ABS Monolith full tower
Rosewell Z3 cpu cooler, two 250mm case fans, 2 120mm fans
Logitec mx3000 wireless
Logitec mx600
dsl 6mps
It could be that the inputs are routed to to one input jack. This can be adjusted on the Realtek control panel to have separate inputs to individual jacks. :)
Win7 Ultimate x64 on Desktop / Win7 Ultimate ...AMD Phenom 965 X4 3.4Ghz cpu Black Edition12 Gb DDR3Nvidea Gforce GTX 470
Dilithium Computers/Engineering (Myself) Star date 42.739285.5432.9
Win7 Ultimate x64 on Desktop / Win7 Ultimate x86 on laptop / Win7 x86 Starter on Netbook
Gigabyte 790XT
12 Gb DDR3
Onboard Realtek hi-fi
Lg 3D led 23"
Loads maxstore sata 1 & 2/ loads of partitions + 1Tb Hitachi sata 2. 256Gb Crucial ssd.
OCZ 700W GameXstream
Artec 10000
On board + many case fans
Logitech wireless K350
Inferno gaming mouse
Talk talk. 10Mb
My PC was hand built with matchsticks. xbox 360 controller. Printers,fax.........
Thank you for your quick answer ;) But i tried all that you said before and it didn't work xD.
In fact the sound works, i can listen to music and everything (so do my headphones) But my mic won't work oO i thought it was broken, but it worked on an other pc.
and for my system, i tried everything: in the control panel or in Realtek manager and this won't work oO and i tried the "separate input jacks" too.
I had same type of problems with vista before but they've been solved by installing the newest Realtek codecs.
Seven
Seven
