AC'97 and HD audio front panel layouts
Dwarf
The Contemplator, (1963-2013)
6:15 PM
Doncaster, UK
This shows the difference between the AC'97 and HD audio front panels.
The main reason for the difference is to do with speaker assignment. With the older AC'97 system, only a single pair of stereo speakers was supported. These could be switched on and off by a standard switching stereo jack socket. With the introduction of HD audio, and the ability to feed upto 8 speakers (7.1 audio), a different method of muting had to be utilized. This method uses circuits built in to the audio chip itself to control the rear socket muting. All the front panel has to do is to provide the correct signals to the audio circuitry to tell it whether it should mute the rear panel or not. To do this, specially designed jack sockets are used. Inserting a set of headphones into the front panel socket will cause all rear panel sockets that have been assigned as speaker sockets to be muted. Since the rear microphone socket can also be re-assigned as a speaker socket, a similar arrangement also exists for a front panel microphone as well. This disables the rear pink (MIC) socket, but not if it is assigned as a speaker socket.
Note that an AC'97 style front panel WILL NOT mute speakers connected to the rear panel of a HD equiped motherboard - only a HD front panel is configured to do so.
Even cases that come with front panels fitted with both HD and AC'97 audio plugs for the motherboard will not mute these speakers as the jack sockets are still the type used for AC'97, meaning that the required muting signals are never received by the audio chip on the motherboard.
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
You're welcome. It's just a pity that HD front panels are somewhat elusive and very difficult to find. :mad:
Gigabyte IF233
Avast! 8.0.1497
IE 11
Nice, thanks.... I've always wondered about the differences.
Ap
Windows 7 Home PremiumIntel Core 2 Duo @ 3.00gHz4 GBATI Radeon HD 2600 XT
Assembled in my workshop
Gigabyte GA-P35-S3G
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
Too take it a little further here is the difference in the pin outs for a the AC97 and HD Audio jumpers on a motherboard,
Also if you motherboard is like mine it will have a setting in the bios where you set it to either, depending on what is on the case.
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
My Lian-Li A77 HD Audio plug is arranged like below.
1 black (gnd)
2 red (port1L)
3 black (presence)
4 brown (port1R)
5 orange (sense1 return)
6 yellow (port2R)
7 key
8 black (sense send)
9 green (sense2 return)
10 blue (port2L)
It looks like I have to swap the pins like this: (or I am nutz)
1 and 2
3 and 4
5 and 6
7 and 8
9 and 10
Note that the socket is on the Supreme FX mini card.
W7 Prof 64 biti7-3770kG.Skill Sniper 1866 16 GBEvga GTX 770
HomieJunker
W7 Prof 64 bit
i7-3770k
Sabertooth Z77
Evga GTX 770
Sound Blaster Z
Asus VG278HE
4 Seagate Barracudas 250 GB
2 Intel® X25-M 160GB
Corsair H1000X
Lian-Li A77B
Phantek 120 dual fans
Corsair K70 RGB
Logitech G502
FiOS Quantum
Avira
Hello i need a little help with analog surround speaker jack detection on the intel DH61AG.how to connect jack detection to get options (analog surround out) on the realtek audio manager.
Windows 7 Ultimate x64i38ghd4000
intel
i3
DH61AG
8g
hd4000
500gb
avast
firefox
intel
i3
DH61AG
8g
hd4000
500gb
avast
firefox
Nothing
intel
i3
DH61AG
8g
hd4000
500gb
avast
firefox
forget about it, hmxdenis.
change/replace the front panel jacks on your computer case; contact the maker of your PC case if they have a special audio wiring cable that can connect to the jack detection pins
Windows 7 SP1 Home Premium 64bit [x64]Intel(R) Core(TM) i5-2310 CPU @ 2.90GHz6 GBIntel HD Graphics 2000
Dell Inspiron 620
Conexant CX20641 HD Audio
Western Digital 1TB (1024GB) WD10EALX-759BA1
Spectrum Cable Internet up to 100Mbps
