Windows 7: AC'97 and HD audio front panel layouts
05 Dec 2009   #1
Dwarf
Windows 8.1 Pro RTM x64
This shows the difference between the AC'97 and HD audio front panels.
The main reason for the difference is to do with speaker assignment. With the older AC'97 system, only a single pair of stereo speakers was supported. These could be switched on and off by a standard switching stereo jack socket. With the introduction of HD audio, and the ability to feed upto 8 speakers (7.1 audio), a different method of muting had to be utilized. This method uses circuits built in to the audio chip itself to control the rear socket muting. All the front panel has to do is to provide the correct signals to the audio circuitry to tell it whether it should mute the rear panel or not. To do this, specially designed jack sockets are used. Inserting a set of headphones into the front panel socket will cause all rear panel sockets that have been assigned as speaker sockets to be muted. Since the rear microphone socket can also be re-assigned as a speaker socket, a similar arrangement also exists for a front panel microphone as well. This disables the rear pink (MIC) socket, but not if it is assigned as a speaker socket.
Note that an AC'97 style front panel WILL NOT mute speakers connected to the rear panel of a HD equiped motherboard - only a HD front panel is configured to do so.
Even cases that come with front panels fitted with both HD and AC'97 audio plugs for the motherboard will not mute these speakers as the jack sockets are still the type used for AC'97, meaning that the required muting signals are never received by the audio chip on the motherboard.
24 Apr 2010   #2
zaratustra06
win xp
Great info, just what I searched for.
24 Apr 2010   #3
Dwarf
You're welcome. It's just a pity that HD front panels are somewhat elusive and very difficult to find.
24 Apr 2010   #4
Aphelion
Windows 7 Home Premium
Nice, thanks.... I've always wondered about the differences.
Ap
24 Apr 2010   #5
stormy13
Microsoft MVP
Win 7 Ultimate x64
Too take it a little further here is the difference in the pin outs for a the AC97 and HD Audio jumpers on a motherboard,
Also if you motherboard is like mine it will have a setting in the bios where you set it to either, depending on what is on the case.
13 Mar 2011   #6
McSeven
W7 Prof 64 bit
My Lian-Li A77 HD Audio plug is arranged like below.
1 black (gnd)
2 red (port1L)
3 black (presence)
4 brown (port1R)
5 orange (sense1 return)
6 yellow (port2R)
7 key
8 black (sense send)
9 green (sense2 return)
10 blue (port2L)
It looks like I have to swap the pins like this: (or I am nutz)
1 and 2
3 and 4
5 and 6
7 and 8
9 and 10
Note that the socket is on the Supreme FX mini card.
Using both front panel audio and back panel: solutions
This possibly should go in the hardware forum since it involves the motherboard as well but being a sound issue I assume here would be better. I have an Asus Xonar DG sound card on an Asus P7P55D-E LX motherboard (and AMD Radeon HD 7800 Series video card) running on Windows 7 Home Premium...
How to disable read audio panel and make the front panel primary?
Hello. I am having a not so common issue of a problematic REAR audio panel jack. The microphone pin got stuck and broken into the rear/back microphone jack and now the OS/driver thinks there is a microphone in the back panel but I just want to be able to make the microphone work on the front panel...
No front Panel audio detected but Rear Audio works on Asus P8H 61-M LX
My front USB slots work and every connector on the rear works fine yet when i plug headphones into the front audio jack and nothing is detected. My Bios are updated to the latest version, i have also tried switching to AC97 but makes no difference. Swapping between HDMI and s/pdif doesn't also...
Asus onboard audio no longer working since enabling front panel audio.
My audio rear outs used to work, but even so, i was primarily using hdmi out from my video card. I was also diagnosing BSODs at the time and sent my mobo back to asus for an rma. When it got back, I placed it in a different case and attached the font panel audio. Due to a new living...
Need help with Front Panel HD Audio
I have had this problem for months and I have never been able to solve it. Bios is set for HD Audio. When I connect the front panel hd audio plug from my Lian-Li A77 case into the Asus Rampage II Extreme Supreme FX mini sound card the system will boot up normally. Then when I plug in the...
help me with the front audio panel :(
hey guys! i'm new here, i just installed windows 7 yesterday, and i having a problem with my front audio pane both headphone and mic are not responding when i plug it in .i had Xp before, and the front panel worked without any problems, but now i can't get it working... tried the , newest driver,...
