Gateway laptop has no sound from Speaker but it has from headphone
  1. Posts : 1
    Hello,
    When i installed Windows 7 everything was fine but only my sound from speaker aren't working. I have Gateway CX2724 laptop. When i had Vista and XP it worked fine but now it doesnt. Please let me know how to fix it. I will appreciate a lot.
  2. Posts : 15
    Vista x64 and Windows 7
    The headphones that work.... they aren't USB ones are they?
    Can you check in DEVICE MANAGER to see if your soundcard is listed there and if it has a driver loaded for it?
  3. Posts : 1,009
    Windows 7 RC 7100 32bit/64bit
    Hello akashtimilsina...
    I can suggest to download the audio driver for Windows Vista and install it in compatibility mode.
    Driver:
    Windows Vista (32-bit/64-bit) Sigmatel Audio Driver version: 6.10.5337.0
    Please post back if it works.
    Cheers
  4. Posts : 1
    I have the same computer and it worked like a charm. Thanks!
