Realtek hd problem..headphones work as speakers..
SORYNXRO
8:14 AM
HELLO,
I have a wired problem with realtek hd r237 windows 7 drivers:
I don't have any sound on laptop's internal speakers but i can hear in headphones.In PLAYBACK DEVICES headphones are detected as speakers and when i unplug them sound automatically turns to SPDIF- no sound on internal speakers.
If a make a sound test (with headphones pluged in) whith Quadraphonic selection i can hear FL in my left headphone ,FR in my right headphone,RL in left internal speaker and RR in right internal speaker.
This is really frustrating ..help!!
win 7
win 7
Can you set the default device to your speakers when your headphones are not plugged in?
Windows 7 Professional x64Intel i7 2600K OC'd @ 4620 MHz16GB GSkill Sniper 2133 Mhz (4x4GB)EVGA GeForce GTX 480 SuperClocked+
Asus P8Z68-V Pro
2x Acer S273HLbmii 27"
2 x 1920x1080
64GB Crucial M4 SSD
Storage: Hitachi 1TB 5400RPM, Samsung 1.5TB 5400RPM
Corsair HW Series 750w (modular)
Cooler Master HAF 932 Advanced Blue Edition
CM Hyper 212+ CPU cooler, 3x 230mm + 1x 140mm case fans
Logitech MK320 (wireless)
30 Mb/s : 2 Mb/s
No i can't
win 7
win 7
Go to Control Panel>Device Manager and see if there are any yellow icons.
Asus P8Z68-V Pro
2 x 1920x1080
64GB Crucial M4 SSD
30 Mb/s : 2 Mb/s
Done that -nothing.Already tried several driver versions..the newest works best,at least i have sound in headphones
win 7
win 7
Have you tried using the Realtek HD Audio Manager to see if you can correct the problem from there?
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
From what i can see REALTEK HD 237 DRIVERS dosen't have an audio manager aplication.I installed older drivers that have that and i cannot hear anything in speakers or headphones
I had my motherboard repaird last week and audio chip replaced but still the same problem
This is what Everest tells me:
Windows Audio
Device Identifier Device Description
midi-out.0 0001 001B Microsoft GS Wavetable Synth
mixer.0 0001 FFFF Digital Audio (S/PDIF) (High De
wave-out.0 0001 FFFF Digital Audio (S/PDIF) (High De
PCI / PnP Audio
Device Description Type
Realtek ALC888/1200 @ nVIDIA MCP67/68 - High Definition Audio Controller PCI
HD Audio
[ nVIDIA MCP67/68 - High Definition Audio Controller ]
Device Properties:
Device Description nVIDIA MCP67/68 - High Definition Audio Controller
Device Description (Windows) High Definition Audio Controller
Bus Type PCI
Device ID 10DE-055C
Subsystem ID 1025-0126
Revision A1
Hardware ID PCI\VEN_10DE&DEV_055C&SUBSYS_01261025&REV_A1
[ Conexant D330 ]
Device Properties:
Device Description Conexant D330
Device Description (Windows) HDAUDIO Soft Data Fax Modem with SmartCP
Device Type Modem
Bus Type HDAUDIO
Device ID 14F1-2C06
Subsystem ID 14F1-0000
Revision 1000
Hardware ID HDAUDIO\FUNC_02&VEN_14F1&DEV_2C06&SUBSYS_14F10000&REV_1000
[ Realtek ALC888/1200 ]
Device Properties:
Device Description Realtek ALC888/1200
Device Description (Windows) High Definition Audio Device
Device Type Audio
Bus Type HDAUDIO
Device ID 10EC-0888
Subsystem ID 10EC-0888
Revision 1002
Hardware ID HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_10EC0888&REV_1002
Audio Codecs
[ AC-3 ACM Codec ]
ACM Driver Properties:
Driver Description AC-3 ACM Codec
Copyright Notice © 2005 by fccHandler
License Information GNU General Public License
Driver Features Dolby Digital AC-3 codec for Windows ACM
Driver Version 1.28
[ Fraunhofer IIS MPEG Layer-3 Codec (decode only) ]
Driver Description Fraunhofer IIS MPEG Layer-3 Codec (decode only)
Copyright Notice Copyright © 1996-1999 Fraunhofer Institut Integrierte Schaltungen IIS
Driver Features decoder only version
Driver Version 1.09
[ LAME MP3 Codec v0.9.2 - 3.98.2 ]
Driver Description LAME MP3 Codec v0.9.2 - 3.98.2
Copyright Notice 2002 Steve Lhomme
License Information LGPL (see gnu.org)
Driver Features only CBR implementation
Driver Version 4.00
[ Microsoft ADPCM CODEC ]
Driver Description Microsoft ADPCM CODEC
Copyright Notice Copyright (C) 1992-1996 Microsoft Corporation
Driver Features Compresses and decompresses Microsoft ADPCM audio data.
Driver Version 4.00
[ Microsoft CCITT G.711 A-Law and u-Law CODEC ]
Driver Description Microsoft CCITT G.711 A-Law and u-Law CODEC
Copyright Notice Copyright (c) 1993-1996 Microsoft Corporation
Driver Features Compresses and decompresses CCITT G.711 A-Law and u-Law audio data.
Driver Version 4.00
[ Microsoft GSM 6.10 Audio CODEC ]
Driver Description Microsoft GSM 6.10 Audio CODEC
Copyright Notice Copyright (C) 1993-1996 Microsoft Corporation
Driver Features Compresses and decompresses audio data conforming to the ETSI-GSM (European Telecommunications Standards Institute-Groupe Special Mobile) recommendation 6.10.
Driver Version 4.00
[ Microsoft IMA ADPCM CODEC ]
Driver Description Microsoft IMA ADPCM CODEC
Driver Features Compresses and decompresses IMA ADPCM audio data.
Driver Version 4.00
[ Microsoft PCM Converter ]
Driver Description Microsoft PCM Converter
Driver Features Converts frequency and bits per sample of PCM audio data.
Driver Version 5.00
win 7
win 7
Gigabyte IF233
Avast! 8.0.1497
IE 11
I just installed Realtek HD audio manager from 2.37 drivers and now i have no sound in headphones or speakers
I tried different settings in audio manager nothing worked ..still spdif when i have my headphones unplugged and speakers when i plug them
win 7
win 7
Did you reboot after you uninstalled?
Asus P8Z68-V Pro
2 x 1920x1080
64GB Crucial M4 SSD
30 Mb/s : 2 Mb/s
Yes i rebooted.Now i figured out that i have sound on headphones only when i let windows install Microsoft High Definition Driver ,when i'm installing realtek hd 2.37 i don't have sound on internal speakers or headphones.Any ideas why ?
win 7
win 7
Why it turns to spdif when i unplug my headphones? It should turn to Rear Left and Rear right where i think my internal speakers are connected
win 7
win 7
I finally have sound in headphones with new Realtek 2.38 drivers.Speakers no sound ,but now when i unplug my headphones i can hear a fade sound in internal speakers for few seconds....
win 7
win 7
Did the sound ever work on your laptop?
Asus P8Z68-V Pro
2 x 1920x1080
64GB Crucial M4 SSD
30 Mb/s : 2 Mb/s
yes..is working now only when i make a sound test with Microsoft high definition driver and headphones plugged in ..
win 7
win 7
I said earlier that i had my motherboard repaired ,audio chip replaced and after than i have sound only in headphones with Microsoft High Definition driver and in internal speakers when i run a sound test..it is a picture on my first post
win 7
win 7
If i put a new sound card in pci express socket will i have sound on internal speakers?
win 7
win 7
i have same trouble downloaded new realtek driver and now i dond have sound manager is there a way to just download the manager.
windows7 32bit
windows7 32bit
To the OP: who replaced your sound chip? Uncle Frank, who knows all about computers, or the manufacturer/OEM?
Asus P8Z68-V Pro
2 x 1920x1080
64GB Crucial M4 SSD
30 Mb/s : 2 Mb/s
to elliottjoey: no u can't download only the sound manager ..i think that u haven't installed drivers properly.follow the instructions carrefully
to Jonathan_King: No ,sound chip was replaced by a laptop service but i think they made a mistake ..initially i had an ALC268 and now Everest detects an ALC888s witch i think that is not compatible with my MB.I talked with the guy from service and he is sure that he replaced with an ALC268 ..he said that i can check if i take a look on my MB.Anyway i m stuck with headphones sound only on Microsoft drivers unless is there a way to redirect somehow sound from headphones to internal speakers by regedit or software.
win 7
win 7
