Asus A8N32-SLI Deluxe Drivers
  1. Posts : 1
    windows 7
    sound problems (humm) OR whistling noise wile useing the asus drivers
    does anyone know how to fix this?
    thanks anyone
    windows 7 x64
  2. Posts : 4,280
    Welcome to seven forums Paprod: Unfortunately finding working drivers for the Nforce 4 boards are slim to none. I assume you installed the latest ACL850 Audio drivers for Vista in compatibility mode Compatibility Mode From the Asus site. http://support.asus.com/download/download.aspx check your speaker plug and cable to make sure they are in good condition and are not picking up any interference from other components. As you can see by scrolling down this thread your not the only one having issues with the Nforce 4 boards. Here is a link to Vista 64 bit driver packs which is one of the better places to find Nforce drivers as stated in another thread by stormy13 http://www.nforcershq.com/forum/nforce-drivers-f28.html
