Windows 7: SB Audigy SE - driver works, sound doesn't
10 Dec 2009   #1
So I have a SB Audigy SE (SB0570) and I installed Windows 7 about a month ago. Initially, my sound did not work even though I installed the drivers correctly. It began working one day when I restarted the computer in safe mode and then restarted it again normally.
Today, however, it failed again. The only thing that I can think of that has changed is that I installed drivers and software for my Sony Handycam last night. I've since uninstalled the software, but to no avail. When I click on the sound icon in the system tray with Winamp playing, I can see the green bar jumping up and down, signifying that there is sound. I've tried using speakers and headphones, so I know it's the sound card that's causing the problem.
I have uninstalled my drivers and I've tried daniel_k's drivers (first the ones that were too new for the SE - lol - and then the ones that were designed for the SE, the 2.0 version), the drivers that Windows 7 automatically downloaded for me, the 917x support pack, and the drivers that Creative provides on their site for Windows 7. None of them made any difference. My current driver reports its version as 5.12.1.2020, and Windows says that it's working correctly.
Can anyone tell me why I can't get sound even though my drivers seem to work? What might have caused this seemingly random problem?
10 Dec 2009   #2
Windows 7, 64 bit Home SP1, Win 8.1.1 Pro 64 bit
Have you checked the Control Panel/Sound Panel to verify your Audigy SE is set as the Default Playback device?
Instead of uninstalling the Sony Handicam drivers, to determine if that was the cause, you could have used the System Restore function and restore to a date PRIOR to installing the Sony. You can also use the System Restore now and see if that fixes it. System Restore can be accessed from Start/Programs/Accessories/System Tools.
10 Dec 2009   #3
Quote   Quote: Originally Posted by frogitts View Post
This type of behavior is par for the course with Creative drivers, once they get hosed you need to go into the file location where the Creative files were and delate every last bit of them. After that you can reinstall them and they will work.
CCleaner and driver sweeper can help but sometimes you need to dig a bit deeper to get all the old files out.
10 Dec 2009   #4
Thanks, that's good advice. Any guidance as to which files, exactly? I'll give this a shot, but I'm flying blind for the most part.
Yes. In fact, the mixer shows that I have the Audigy selected and that sound is indeed being passed to the card. The only other sound device I have installed is motherboard sound, and that is disabled. Digital output is not selected.
Good idea! I upgraded from XP, so I was a little wary of system restore, but it seems to automate itself very well in 7. Unfortunately, even after running a chkdsk /r on my Windows drive, I still get an error, no matter which restore point I choose. See the attachment for detail.
11 Dec 2009   #5
Just a small update - I uninstalled the driver, prevented Windows from automatically reinstalling it, ran CCleaner on the registry, and then reinstalled the appropriate daniel_k drivers. I got a new message that I had never received during the installation process before: Windows wanted me to verify that I really wanted to install the drivers even though it couldn't verify them. I said yes, restarted, and the problem remains. It looks like I have sound, but I have no sound
11 Dec 2009   #6
Hi frogitts,
You could try this
1) Open Device Manager, locate your soundcard, right click it, choose Uninstall, check "Delete driver files" and click on OK. Reboot when prompted to do so.
2) Boot into Safe Mode:
For 32-bit: Open the \Windows\System32 folder and delete APOIM32.EXE, APOMngr.dll, CmdRtr.dll.
For 64-bit: Open the \Windows\System32 folder and delete APOMgr64.dll, CmdRtr64.dll.
Now open the \Windows\SysWOW64 folder and delete APOIM64.EXE, APOMngr.dll and CmdRtr.dll.
Now delete the following registry trees:
For 32-bit: HKEY_LOCAL_MACHINE\SOFTWARE\Creative Tech\Software Installed\APOIM
HKEY_LOCAL_MACHINE\SOFTWARE\Creative Tech\Installation\CTRedist\APOIM
For 64-bit: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Creative Tech\Software Installed\APOIM
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Creative Tech\Installation\CTRedist\APOIM
3) Reboot and install the Support Pack.
Hope that helps
11 Dec 2009   #7
Try doing this in sound properties, change to DVD quality 48000.
11 Dec 2009   #8
Quote:
You could try this
Tried that, and no change. Interestingly enough, the only file or key that existed on my computer was APOIM32.EXE (I'm running 32-bit). I also tried deleting all Creative registry keys, but still no change.
Good thought, but it's already set to DVD Quality 48000.
I'm starting to wonder how I even got this working in the first place!
12 Dec 2009   #9
Problem solved!
After countless restarts, the problem was solved by simply turning my computer off, leaving it off for a few hours, and turning it back on. I would imagine that this indicates a hardware issue, but that's a story for another day.
12 Dec 2009   #10
Glad that you got it working. Thank You for posting back
Similar help and support threads for2: SB Audigy SE - driver works, sound doesn't
HDMI Sound Works but Audio Jack Doesn't Sound & Audio
Realtek sound driver doesn't install Sound & Audio
Sound Blaster Audigy 2 Platinum ex does not sound in Win7x64 Sound & Audio
Creative Sound Blaster Audigy 24bit Sound Card Drivers
Audacity. Sound recording doesn't works. Software
Sound Blaster Audigy Sound & Audio
No sound with Audigy 2 sound card? Sound & Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
