Windows 7: Audio Problem solved
12 Dec 2009   #1
fengzj
Windows 7 Ultimate
Like other posters who have audio problems with Windows 7, as a last resort before Microsoft puts out a workable driver for onboard Realtek sound card, I uninstalled the version (6.0XXXXX ?) that came with Windows 7 and installed the 25/4/2005 version (5.10.0.5125) that came with my Asus P5LD2 motherboard. It's working like charm now.
After restarting the system, it will complain that the version of driver is not compatible with Windows 7. Fortunately it gives you an option to run the program, just click "Run Program" and that's it.
13 Dec 2009   #2
CCDubs
Before I go and look for this driver, does anyone know if this is actually true?
10 Jul 2010   #3
salaadin19
Windows 7 x64 Pro Retail
maybe
Quote   Quote: Originally Posted by CCDubs View Post
It might work, especially if you are using the 32bit version of Win7.
Alternatively, all you have to do is find a relatively similar driver (one from the same series, or even just the same general platform) and just edit the driver to include your card. If you are at all technically proficient, please see my thread (first post) and modify the instructions to suit your card. I am sure it will work (if you find an appropriate enough driver)
Cheers!
ZV6000 Audio x64 solved
For those of us who have been having a major head-ache with ZV6000 after updating to retail, or those of us who never had audio working on the x64 side ever, here is the final solution (provided below with edit for ZV6000): Download the "Conexant AC97 Audio Driver for Microsoft Windows Vista...
[solved] Problem to install SP1 - bcdedit problem
Dear all, My problem is solved, but it took me so long to get it solved that I decided to post my experience in case it could help someone else. Sorry if I'm not very precise in the manipulation I did, I don't remember everything precisely. My 1st problem: SP1 failed to install when running...
Windows Updates & Activation
Boot Hang Solved; separately Sleep Problem Solved
I want to share how I solved these problems to give back to the many posters I read here who helped me. First, the sleep problem. The second day after I installed Windows 7, the computer went to hybrid sleep (s3) overnight. When I moved the mouse the case light came on, the fans roared to life...
Performance & Maintenance
Solved my problem
I'm not sure if I'm posting correctly and hope I'm not violating any rules - but I wanted to share how I was able to fix my window update problem with everyone - so that if anyone else has this problem it could help them (smile)! I couldn't update and a virus or the removal of it must have...
Punk buster bf2 , was this problem solved?
hey guys i saw a while ago on the forums about the whole issue about punk buster and what not, was that issue solved? I keep getting kicked out because of this reason Restriction: Service Communication Failure PnkBstra.exe i have tried to search the forums but haven't found the cure for...
Gaming
First Win7 sleep problem-Solved
I've had trouble free first month of Windows 7 Ultimate x64 so far which is good because Vista's equivalent gave me countless sleep problems namely a completely random sleep issue. I woke my pc up from sleep this morning to find my dvd-rw could no longer see blank cd's. After the upperfilters...
General Discussion
