X-Fi Fatality Pro, Mic won't work
Firstly I have read the following post, this may save some time.
Creative Fatal1ty Gaming Headset - Microphone Problem Reply to this Post Post Reply - Vista Forums
[IMG]file:///C:/Users/Rigg3r/AppData/Local/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/Users/Rigg3r/Desktop/CONTROL%20PANEL.jpg[/IMG][IMG]file:///C:/Users/Rigg3r/Desktop/CONTROL%20PANEL.jpg[/IMG]
I am using a Medusa 5.1 surround sound setup with external control box and I plug it directly into my Sound blaster with jack leads. This is the card I use.
Creative PCI Express Sound Blaster X-Fi Titanium Fatal1ty Professional Series Sound Card
I have posted a pic of what I can see, I have tried turning off the 'line in', the 'digital in' and the 'what you hear' in order to try to get the soundcard to pick up the analogue signals. All with no success.
I have been using this setup with XP with no issues, and have just installed windows 7.
I have checked the device manager, and although I have 2 driver issues (1 for a mass storage device, the other for an 'unknown device), the soundcard appars to be fine.
I have tried using Skype and teamspeak, I can hear other people perfectly well.
The microphone is plugged into the correct port.
I downloaded windows 7 specific drivers from creative for my soundcard, and installed them when I put windows 7 on my system.
Have exhausted my limited knowledge/expertise, now I'm stuck ^^
If anyone could help I'd be very grateful.
