Windows 7: external card, and front audio on pc case
15 Dec 2009   #11
Microsoft MVP
Win 7 Ultimate x64
sotorious from having a look at the various Xonar cards here, - Computer Hardware,Input Devices,Sound Cards,ASUS
it looks to me like the D2 and the D2X (same as D2, only PCI-E instead of PCI) are the only two cards that don't have a front panel connector on them.
15 Dec 2009   #12
windows 7 professional 64 bit
Ok any good recommended sound cards, that have that option and that are pretty up to date with windows 7??
Search this Thread:
Advanced Search
AC 97 front audio cables on this mb front audio? msi ms-7548
msi ms-7548 Motherboard Specifications, MSI MS-7548 (Aspen) | HP® Support this is a cable i have plugging in for a test wont short the board? I am interested if you can have front audio and spdiff output sound. HP says ---> One 9-pin audio header for headphone-out and microphone-in...
Upgraded case - Multiple Issues - Front audio not working + USB cutout
Hey there, so i changed my PC case today and have been having the following issues: Speakers plugged into the rear panel work fine however when i plug my headset into the front panel i can't hear any sound / it doesnt work at all. Also, my wireless network stick and keyboard keep randomly...
PC Custom Builds and Overclocking
No audio through external sound card on web only
I have a Acer with Windows 7 Ultimate x64 and my headphone jack is broken. When i want to listen to music or any audio on the web the sound plays through my laptop speakers. I have the vms2 audio midi device configured as my default player. All other audio including traktor plays audio through my...
Stereo Audio Output Inverted on Realtek Front Panel and Firewire Card
Hi, I just realized that stereo output is inverted (L&R are swapped) on my Realtek front panel headphones connector and on my M-Audio Firewire card. Output is OK on Realtek rear main/front speakers connector. Any ideas on how to fix this? Thanks, J
Connecting "HD audio" cable from front panel to sound card
My sound card Xonar D1 doesn't work properly and i wrote to ASUS and they told me to connect the "HD audio" or "speaker" cables from the front panel of motherboard to the sound card's front panel. Is that safe to do? weather it will work or not, is it safe to try?
Connecting Front Panel Audio to Sound Card
I have a front audio panel and a CMI 8738-6ch sound card. The front audio does not work and has a wire coming directly from the back of it with this plug on the end of it... There are...
