no sound after sleep mode
agreenorangpeel
1:46 PM
Hello, I have recently installed windows 7 on my laptop and i am having the same problem i had with the beta. Upon start up, the audio works fine but after i close my laptop and it goes into sleep mode, when i come back and open it the audio no longer works. I cant hear anything. I dont know what sound card i have or how to find out. Any help would be greatly appreciated , thanks a bunch !
Alex
windows 7intel core 2 duo t54508800 gts
gateway p-6831fx
windows 7
8800 gts
Hello, Welcome to the Forums!
Try typing msinfo.exe into the run box and it should show you your specs. Alternatively, you could download Speccy, and it will make things a lot easier.
After you find your sound card, try going to the manufacturer's site and downloading drivers for it. They are usually located in the support section.
Hope this help,
~Jonathan
Windows 7 Professional x64Intel i7 2600K OC'd @ 4620 MHz16GB GSkill Sniper 2133 Mhz (4x4GB)EVGA GeForce GTX 480 SuperClocked+
Asus P8Z68-V Pro
2x Acer S273HLbmii 27"
2 x 1920x1080
64GB Crucial M4 SSD
Storage: Hitachi 1TB 5400RPM, Samsung 1.5TB 5400RPM
Corsair HW Series 750w (modular)
Cooler Master HAF 932 Advanced Blue Edition
CM Hyper 212+ CPU cooler, 3x 230mm + 1x 140mm case fans
Logitech MK320 (wireless)
30 Mb/s : 2 Mb/s
Hello Jonathan, thanks for your help. Unfortunately under Audio my sound card is listed as High Definition Audio Device. That doesn't really tell much. I just found this post http://www.sevenforums.com/drivers/30965-no-sound-after-sleeep.html with someone who had the exact same computer as me and the exact same problem so maybe ill try to message them about it.
--EDIT--
IDT/SigmaTel Audio Driver Version: 6.10.5939.0 Download, extract, run setup it works awesome now . Apparently this is a problem that gateways have ^ ^ !
gateway p-6831fx
windows 7
8800 gts
