Need sound card recommendation
Sheryl
12:23 PM
I am using W7 Home Premium 64 on a Dell XPS 600. The sound card is a Creative SoundBlaster X-Fi Xtreme Music. The sound is awful (when I even HAVE sound). Crackling and popping and then stopping altogether. Looking on the Creative site, it seems the most recent drivers are 2006 (I know, I don't have the most recent computer!).
If I opt for a new sound card, what should I get?:confused:
Windows 7 RC2.80 GB Intel Pentium D2046 MegabytesNVIDIA GeForce 6800
Dell Inc./DXG051
Windows 7 RC
Dell Inc. 0XH241
2046 Megabytes
NVIDIA GeForce 6800
Creative SB X-Fi
Dell 205FPW
NVIDIA STRIPE 320 GB
Yep those Creative drivers pretty much suck. My son gave up on his X-fi card also. The problem with Creative drivers is that once they get messed up you need to go in and find all remnants of the old driver and remove them, just uninstalling isn't enough with Creative drivers.
I wouldn't trade my Asus Xonar D2 for anything.
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
GSkill Phoenix Pro 120GB SSD
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
Budget?
Windows 8.1 ProIntel Core i5-2500K8GB Corsair Vengeance DDR3Sapphire Radeon HD 7970 GHz Vapor-X Edition
Windows 8.1 Pro
Intel Core i5-2500K
ASRock Z77 Extreme4
Realtek ALC898
BenQ XL2411T
1920 x 1080 @ 144Hz
Plextor M3 Pro 128GB
WD Caviar Blue
Seasonic G Series 650W
Corsair Obsidian 650D
Corsair H60 2013 Edition
Cooler Master Quick Fire Rapid
Corsair Raptor M45
Headphones: Sennheiser HD-515
I'm not a gamer (well, I play all sorts of solitaire and word games, but...). All I want is to play music through iTunes and have my computer give me all the proper alerts and so forth. Also hear the video on YouTube. So I don't need much. Under $100 would be good. Maybe up to $150 if it's really necessary.
Would the native sound on my motherboard be sufficient?
Dell Inc./DXG051
Windows 7 RC
Dell Inc. 0XH241
2046 Megabytes
NVIDIA GeForce 6800
Creative SB X-Fi
Dell 205FPW
If you don't have a good set of speakers then the onboard sound would be fine. With good speakers and soundcard you would have much better sound though. You get what you pay for really.
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
This.
Windows 8.1 Pro
Intel Core i5-2500K
ASRock Z77 Extreme4
Realtek ALC898
BenQ XL2411T
1920 x 1080 @ 144Hz
WD Caviar Blue
Corsair Raptor M45
Usually most sound cards on current mobos are OK -- especially if you are only using it for Itunes -- pretty horribly compressed music which will sound AWFUL if passed into a really high quality "Old Fashioned Hi Fi" amplifier in any case.
I'd actually look at a streaming solution as well -- but that's another issue.
For Itunes any built in audio system will be MORE than adequate. Don't even THINK of spending 150 USD on this --save your money.
If your computer speakers are junk - for around 35 USD you'll be able to pick up some speakers which will do the job just fine.
For decent Classical Music/ symphony Orchestras, good DVD sounds and games other issues apply but for your case stick to the native sound card.
Cheers
jimbo
Intel i7 Intel i5
8GB, 16GB
On Motherboard
Realtek HD audio
1920 X 1080
4 X 1TB SATA
Toshiba wireless laser
> 20MB up
Thanks. I'll give that a try and see. My computer is not new, so maybe it won't work so well, in which case, I'll ask again!
Dell Inc./DXG051
Windows 7 RC
Dell Inc. 0XH241
2046 Megabytes
NVIDIA GeForce 6800
Creative SB X-Fi
Dell 205FPW
Latest X-Fi XtremeMusic I see at Creative is June 26th 2009:
Driver
Creative Sound Blaster X-Fi series driver 2.18.0013
Filesize : 54.1 MB Download
Release date : 26 Jun 09
Creative Worldwide Support
Windows 7 Professional x64AMD Phenom II X4 9254x1024mb Kingston HyperX DDR2-1066 KHX8500D2/1GAsus GTS 450 OC
Asus V2-M3M8200 Barebones
V2-M3M8200 (basically a M3N78-VM)
Asus GTS 450 OC
Creative Sound Blaster X-Fi Titanium PCIe
Asus 24" LCD VH242H
WDC WD5000AAKS
WDC WD5002ABYS
Seagate ST325062 USB-to-IDE
Fujitsu 160GB Pocket USB HDD
Antec Earthwatts EA-430D
Asus V2-M3M8200
120mm side fan & 80mm front & 92mm rear fan
Dell USB mini Multimedia
Logitech MX518
Comcast Xfinity
Logitech Webcam Pro 9000
Accurian 40-1462 Speakers
little dot MKII Headphone Amp
Yeah, I have that driver. But I still am having no luck. I currently have no sound at all. Onboard sound didn't even work.
This is just the straw that broke the camel's back. I'm thinking of getting a Mac and the hell with it.
Dell Inc./DXG051
Windows 7 RC
Dell Inc. 0XH241
2046 Megabytes
NVIDIA GeForce 6800
Creative SB X-Fi
Dell 205FPW
