My sound problem
neo866
11:28 AM
Not sure if anyone can help but my sound problem is this:
I have an external soundblaster card and an M-Audio Fast Track Pro card both were working under Window xp but since i upgraded to Window 7 i have a crackling sound when i scroll a window up or down.
It's the same for movies, Music and any sound (youtube) coming from my pc.
At first i thought it was a problem with my soundblaster card so i used my Fast Track Pro and i get the same crackles.
I've updated all my drivers (sound/Graphics) but still no joy.
The sound is fine when i keep a window still but as soon as i move it about the crackling starts.
Starting to think i made a mistake upgrading!
windows 7 home premiem 32bitAMD Athlon 64x2Nvidia 6200
AMD Athlon 64x2
Asustek av8-vm
Nvidia 6200
Soundblaster + M-Audio Fast Track Pro
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
GSkill Phoenix Pro 120GB SSD
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
I have a Sound Blaster Connect card, Model number sb0270. but i'm sure i have the right drivers but you never know!
Also as i said i tried it with my Fast Track Pro external card and i still have the exact same problem and i've updated my m-audio drivers as well.
AMD Athlon 64x2
Asustek av8-vm
Nvidia 6200
That is just the problem, the Creative drivers don't work for hardly anyone "typical Creative support" which is why the Daniel K ones are usually the way to go.
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
Ok, where do i get the Daniel K drivers from? But how does this explain my other sound card not working?
Sorry for the questions but i'm new to this
AMD Athlon 64x2
Asustek av8-vm
Nvidia 6200
How does this explain it? Easily it's a driver problem with a new Op system. This happens when ever a new Op system arrives on the scene.
Let me look around and see if I can find it.
According to Creative this is the one for Windows 7 32 bit.> http://support.creative.com/Downloads/welcome.aspx
From this list here your card is near the bottom.
http://support.creative.com/kb/showarticle.aspx?sid=61105
I believe the Daniel K version is here > http://www.filefront.com/14952823/P17X_SupportPack_2_0.exe/
It gets confusing as there are hundreds of different Creative cards.
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
Ok i give them a try, thanks
AMD Athlon 64x2
Asustek av8-vm
Nvidia 6200
