Windows 7: Front audio problem and Realtek Issue
25 Dec 2009   #11
win 7
Ya it was pretty down hill, i settled for mic and headphones working alongside speakers and not showing up... thanks for your help
Search this Thread:
Advanced Search
Realtek HD Audio Drivers - Constantly detecting/undetecting front jack
Hello all, I rercently came with the following problem without any reason: I have a realtek audio chipset with my mother board. Since some time, the HD audio drivers keeps on detecting/undetecting a device plugged in my front jack (resulting is sound cutoff, which is more than annoying)....
Front jack not working for Realtek HD Audio on Windows 7
Hi all, I've just installed Windows 7 and was very happy to see all the hardware working, even my Realtek HD Audio sound card, except the front jacks. On windows XP I could solve this by with the Sound Manager that comes with the realtek drivers, and select the "Disable front panel jack...
Stereo Audio Output Inverted on Realtek Front Panel and Firewire Card
Hi, I just realized that stereo output is inverted (L&R are swapped) on my Realtek front panel headphones connector and on my M-Audio Firewire card. Output is OK on Realtek rear main/front speakers connector. Any ideas on how to fix this? Thanks, J
Realtek HD front panels problem
The microphone jack on the front panel of my computer is having detection problems. I have tried the "disable front panel detection" option and then my mic works perfectly after that. However, whenever I hit the mute switch on my microphone, whatever is playing on my computer gets broadcasted from...
Realtek HD audio - Front jack makes cracking sound
MODS: I post this thread to isolate the most important problem from my previous thread and to make it clearer and easier to answer. I hope that's alright. I have this on onboard Realtek HD audio card. And no matter if I connect the AC'97 or HD audio adapter to the motherboard, the sound that...
Realtek front panel- audio & mic not recognised
After connecting to the front panel my headphones (audio and mic), nothing happens, no sound through them. How to fix that? IS this tut about that? If so, I didn't find DevType_0888_SS147b1083...
