Windows 7: Conexant AC-97 Audio HELP, PLEASE!
26 Dec 2009   #1
Soufiane
Windows 7 Ultimate 64-bit
Hello everyone,
I hope everbody's doing well. Please, I do really need your help to fix a problem with my Sound Card ''Conexant AC-97 Audio'' I have recently insalled Windows 7 Ultimate 64-bit and it seems to be working fine, though this particular issue with the sound card drivers. I have tried a lot starting by the solutions suggested by users on this forum but never gotten to fix the problem.
Here are two photos I have taken from a screan scan which will show you exactly what's wrong, and I know that many people have the same issue ...
http://img683.imageshack.us/img683/8359/photo1r.jpg
http://img706.imageshack.us/img706/2106/photo3gz.jpg
I do highly appreciate any help on this, and thank you very much in advance ...
26 Dec 2009   #2
Soufiane
Please help! I am going crazy here! I've tried all that I know so far but nothing worked. I do really need your help guys ... Thanks!!!!!!!!
26 Dec 2009   #3
Qdos
All you appear to need to do is install the drivers...
Read the following, inparticular posts one and eight...
26 Dec 2009   #4
Soufiane
Quote   Quote: Originally Posted by Qdos View Post
Thank you for your kind reply, I have followed the instructions BUT unfortunately no positive results Here is a photo that shows what happened after doing those steps ...
http://img33.imageshack.us/img33/3540/resultw.jpg
26 Dec 2009   #5
aem
Windows 7 Ultimate 64Bit
It looks like you need drivers for those device with yellow exclamation marks. Can you provide the PCI IDs for those? Hows how to get the info.
Driver selection for your Hardware devices.
27 Dec 2009   #6
Soufiane
Quote   Quote: Originally Posted by aem View Post
Thanks alot for trying to help out with this complex issue, here are some pics will show you what is going on exactly with my machine!
http://img696.imageshack.us/img696/3299/88897254.jpg
http://img43.imageshack.us/img43/5340/26879511.jpg
http://img145.imageshack.us/img145/6431/38499496.jpg
http://img200.imageshack.us/img200/2338/96358679.jpg
27 Dec 2009   #7
aem
In the Details tab, under Property, select Hardware ID. You haven't doen this.
27 Dec 2009   #8
Soufiane
in the details tab, under property, select hardware id. You haven't doen this.
pci\ven_8086&dev_266e&subsys_3082103c&rev_03
pci\ven_8086&dev_266e&cc_040100
27 Dec 2009   #9
aem
Have you tried installing this?
PC HD-Audio Modem Combo
27 Dec 2009   #10
Soufiane
Thank you very much guys for trying to help out, I appreciate it
I last thing I tried and it's seems working fine is this method I found at another website and I want to share with the others who might have the same issue and thank you once again
Download the "Conexant AC97 Audio Driver for Microsoft Windows Vista (64-bit)" from http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-51288-1
installing it regularly didn't work but you can make a trick.
1. first, try to install it normally with the driver. it will probably fail but it will be extracted in C:\swsetup\SP35558 by default
2. open the .inf file and locate
[Conexant.NTamd64]
%*WDM_AMCAUD.DeviceDesc%=WDM_AMCAUD,PCI\VEN_1002&DEV_4370&SUBSYS_308B103C
%*WDM_AMCAUD.DeviceDesc%=WDM_AMCAUD_DF,PCI\VEN_1002&DEV_4370&SUBSYS_308E103C
3. add this line to it
%*WDM_AMCAUD.DeviceDesc%=WDM_AMCAUD,<x>
<x> can be found by going to the device manager, open the unrecognized audio device's property page, select "Details" tab, and select "Hardware Ids" from the Property combo. One of the listed strings should be <x>. it was the top one in my case.
In my case <x> was PCI\VEN_8086&DEV_266E&SUBSYS_3082103C&REV_03
so it eventually looked like:
[Conexant.NTamd64]
%*WDM_AMCAUD.DeviceDesc%=WDM_AMCAUD,PCI\VEN_8086&DEV_266E&SUBSYS_3082103C&REV_03
4. now install the driver manually through device manager. It installed as "Conexant AC-Link Audio" which i find weird since it first was listed as "Conexant Realtec AC-97".
conexant HD audio not working windows 7 64 Bit
I have encountered issues with Conexant HD Audio driver. When I install driver there will be no sound and when I uninstall it there will be sound. Here I am attaching my computer specifications. Thank You. http://i.imgur.com/i1Lvffo.png
Conexant AC-Link Audio Drivers
Hey folks, I've been looking for the driver that's compatible with Windows 7 for this integrated sound, and I can't seem to find it. I've included the Hardware ID below. Any help would be much appreciated. Thanks in advance.
Drivers
Mic Problem (Conexant HD Smart Audio 221)
Hi, Ive been looking for a solution for so long ! Looked everywhere and no answers so i am posting here. My problem is that when i plug in an external mic, it does not work but the internal mic does work. I am running HP G60-348CA Windows 7 Conexant HD Smart Audio 221 (Date released:...
I have Windows 7 beta loaded on my HP Pavilion zd8000 portable, so far everything seems to be fine except the audio. This computer has a Conexant AC-97 audio chip. The sound is coming out like it is going through a reverb unit set on high. Everything sounds like a bad stutter. Once in a while...
Conexant AMC Audio
Hi, I am looking for the windows 7 drivers for Conexant AMC Audio. Toshiba Satellite L20 PCI\VEN_1002&DEV_4370&SUBSYS_FF311179&REV_02 PCI\VEN_1002&DEV_4370&SUBSYS_FF311179 PCI\VEN_1002&DEV_4370&CC_040100 PCI\VEN_1002&DEV_4370&CC_0401
Drivers
Issue with Conexant Audio driver
Hi all, I'm experiencing some issues with my Conexant audio driver and I'm hoping someone could help me out. I have a Toshiba P100-437 laptop and for some reason my audio stops working after a couple of reboots. So here is the scenario: I install a fresh copy of Win7. It installs a "High...
Drivers
