Windows 7: Realtek - sound not working right.
27 Dec 2009   #11
Windows 7 Professional x64
You're welcome. Your solution is worth reading, though. You never know what other people might read this later on.
01 Apr 2012   #12
Windows 7 Professioal 32 bi
Thank You - Sound works now
To Onyx:
If it wasn't for you I could have spent days trying to fix the sound problem. I checked out the pictures you posted with the setting and my was changed. It must have happened when I downed loaded Amerisoft conversion software.
I'm very grateful. jjb
Search this Thread:
Advanced Search
Realtek/Windows Sound not working but detecting devices.
As the title suggests, my on board sounds, seem to have failed, every time I boot, I get a Windows Troubleshooter telling me that the audio devices and services are not enabled or started, the troubleshooter fails without any errors to report (will grab a screen of this when I can) Here is a...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
New MSI mobo with realtek sound not working
Hi i have a new MSI mobo H61M-P31(G3) that i used to replace a Dell mobo(unknown model) everything fit right and all drivers installed right but still have no sound. I'm not sure if this is due to a driver conflict because i did not reinstall windows or if it is a fault on the board. Yes i have...
No sound, Realtek sound inputs assigned randomly
The realtek audio managers shows that the front two inputs, front mic and headphones, are always plugged in when there is nothing in them at all. When I plug in my speakers to the back green input for sound it inputs both the green one, front speakers out, and the blue input, line in. Now I get...
sound problems with Realtek ALC 882 sound card
I have a HP Media Center PC. the Model number is a1412n I am dual booting xp and windows 7, and in windows 7 I am not getting any sound. When I went to check it out, I realized that the computer was only recognizing the front audio jack. So i plug my speakers into the front jack but it still says...
realtek ac97 no sound,but shows its working
Knowing my luck,I have overlooked a setting,but either way my sound is not working,i recently installed win 7 build 7100,and my onboard sound card is not working,my sound properties and volume control shows it is working but there is no sound coming out,ive checked the volume and all the stuff that...
