Windows 7: SB X-Fi Xtreme Audio driver problem with windown 7
31 Dec 2009   #11
Night Hawk
W7 Ultimate x64/W10 Pro x64 dual boot main build-remote pc W10 Pro x64 Insider Preview/W7 Pro x64
Once you have things working well there's one thing to know about the optional hardware updates. If you have already gone to the manufacturer for the latest and download the same again off of the update site that can literally trash a working setup.
Typically the updates will see the application side as well as the latest driver set which go hand in hand. The second install of the drivers alone offset that too often where you end up starting all over again. Board chipset drivers unavailable at the board manufacturer on the other hand are generally found with the updates. It kind of works in reverse that way.
Search this Thread:
Advanced Search
Creative X-fi Xtreme Audio
Bought this card today. Because it said support for vista, I thought it would work in Windows 7 as well. Installed the card and I had immediately sound. Then I went to the creative site to install the drivers because I had only control over the volume. There was no EAX, no bass control, nothing....
Creative Sound Blaster X-Fi Xtreme Audio PCI - microphone problem
Hello there. Yesterday i've installed this sound card and everything works fine but no microphone. I can see it in control panel but it doesn't work. Mic is fine as i was using it before. I have Win 7 64bit. If you have any idea what can cause the issue please help, if nothing will work i will...
Creative SB x fi xtreme audio delay problem!
Hi, I've recently bought a creative SB x-fi xtreme audio, and no matter what update i do, I keep having delay problems( 0.5 to 1sec) when connecting my guitar through the mic/line entry....... To make things worse, the driver even crashes and all sounds get delayed, i mean even in windows media...
hello, i posted few days ago request for help in one thread from xfi but no help, so im starting new thread. so : i have SB X-Fi Xtreme Audio PCI OEM. can someone help me step by step what to do to enable the mic ? have following problems : cant find any useful drivers cause during...
Creative X-Fi Xtreme Audio Driver Problems
I recently installed Windows 7 on my computer and downloaded the new .90 driver for my "Creative Sound Blaster X-Fi Xtreme Audio" PCI. I can't seem to switch between the recording device "Microphone"(front Jack) and "Line-In"(Back). Also I tried downloading the driver package that includes the...
Does anyone know where i can download drivers for this card for the Windows 7 RC1? ive tried the Beta drivers off Creative and had no joy, the ones that came out when the "leaked" RC1 was out and im gettin majorly cheesed off.... ive got everythig else set up how i want except the fact ive no sound...
