Problem with my sound
Simple
8:58 PM
My speakers seem to be emitting a wierd buzzing sound when doing the following things:
Playing eve online
Scrolling in internet explorer
viewing facebook in firefox
moving windows around the screen
Minimizing and maximizing screens
Even when muted, the sound still comes out. I am not sure what to do. I tried updating drivers and checking for loose wires, but nothing has worked. Please help?
I have windows 7 on this http://secure.newegg.com/WishList/MySavedW...aspx?ID=9164925 if that helps.
I can still hear normal sounds, but it still makes the buzzing sound.
What speakers are you using? I had a 2.1 logitech cheap set, $40, that would buzz all the time. It was OK as with any sound you could not hear it but it was there none the less. They would also "buzz" more when moving the mouse or windows. New speakers, no buzz. :D
With updated drivers and cables checked it might have something to do with the shielding in the speakers. Try moving them, it did not help my old set but worth a try.
Good luck,
Windows 7 x64 build 7068AMD Phenom II X3 720 @ 3.6 GHz2x 2GB G.Skill DDR 3 1333EVGA GTX 285 @ 702 core 1609 shader 2648 memory
Ground Up
Gigabyte MA790XT-UD4P AM3
Onboard Realtek ALC889A
ViewSonic VX2640w
SAMSUNG 7200 320GB (Boot)
Seagate 500GB (Games, Music, Files, Work)
WD 1TB X 2 (DVD's and Blu Rays)
Corsair TX850w (12v 70Amps), Backup: CyberPower 810watt UPS
Antec 3000
ZEROtherm 120mm Copper CPU, 4 X 120mm Case & 1 140mm Case
Microsoft Natual 4000
Logitech G5
Cable
Work System: Win7 x64 7068, Phenom II X4 940 @ 3.6, ASRock K10N780SLI mb, EVGA GTS 250 512mb video, Corsair TX650 power, 2x 2GB G.Skill DDR2 6400, Seagate 250GB, and a lil 17" old LCD.
