Audio Question
  1. Posts : 16
    windows 7 32 bit
    Audio Question
    So I just built an htpc and hooked it up to my 32 inch lcd tv. I have it hooked up through hdmi(best resolution by far when comparing to pc input). I then bought a pair of 2.1 speakers to hook up to the system as well. My plan was to hook them up to my headphone jack on the tv but I just realized I do not have a jack on the lcd. Now would I be able to hook the speakers up to the computer and have it play audio as well? I am concerned that once you plug in something via HDMI it only outputs both audio and video through that connection and no others. However I hope that is not the case. Thanks everyone.
  2. Posts : 9,582
    Windows 8.1 Pro RTM x64
    That I cannot tell you as I don't have a HDMI interface on my system. Others will, and can probably give a better answer. But why don't you just try it and let everyone here know what happens?
  3. Posts : 8,135
    In all cases I've seen (may not have seen them all :) ) you can't have both. You can have the HDMI or the PC's speakers.
  4. Posts : 1,360
    win7 ultimate / virtual box
    I use my monitor and my LCD TV and I initially had to force it to output audio through my HDMI out, I would say you can choose your preferred output by going to control panel\sound and pick your PC soundcard as your device
  5. Posts : 6,879
    Win 7 Ultimate x64
    Correct. As fireberd said you can only use one at a time, but you can choose which to use.
  6. Posts : 16
    windows 7 32 bit
    So I could still use pc audio and hdmi video? I wont be able to try until later in the week when I get the cable.
  7. Posts : 1,360
    no , I reckon fireberd said it best
  8. Posts : 16
    windows 7 32 bit
    Update..PC speakers work fine when pc is hooked up to tv via hdmi.
  9. Posts : 9,582
    Thanks for letting us know. :)
