Creative SB X-FI Elite Pro Not working
Hello,
From the topic title, I have that sound card. I install the latest driver from Creative which is version 2.18.0013. Installs fine, reboots, then the AutoUpdate program comes up to install all the other applications for my device.
However, if I try to run like Creative Audio Control Panel, which got installed during driver installation, it says "The audio device supported by this application is not detected. The application will exit." Even if I install the other application, it will say almost the same message, when I try opening most of them.
I have researched this and contacted creative, but they are never no help, and from what I understand, lot of people are having basically the same issue with the drivers compatibility in WIN 7? Is that correct?
Does anyone know of a solution or do I just have to wait?
I have checked all hardware installations, and they are all good. This worked on Windows Vista x64 with my current system.
Thanks for all your replies, :)
Peyman
