using USB headset and onboard audio plugs at same time
ctanner
12:21 AM
I have a USB headset that I use for gaming, but want to use the 3.5mm jacks on the back of my pc to run a pair of desktop speakers to play music or youtube, etc. I do not want to have to switch the default between the USB headset and the speakers, but to have sound coming out of both at the same time. Is this possible with windows 7?
ctanner, welcome to the forums.
In Windows default audio settings, no it isn't possible. You can however do it if the media player you are using is anything other than WMP and allows you to select which audio device to use when more than two are present. Winamp for example allows you to choose which device to use for playback in its settings.
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
It'd be possible if you added an external USB soundcard, but who can discern
between two simultaneous yet different autio streams? :confused:
W7 x64Intel Q9300 2.5Ghz Quad LGA775 (Would like Q9...4Gb OCZ Gold 1,333MhzPalit HD4850 O/C Sonic 512Mb DDR3, Dual DViD's
Custom built machine
W7 x64
Intel Q9300 2.5Ghz Quad LGA775 (Would like Q9650)
Gigabyte GA-EP45T-UD3R (F6 Bios)
Azalia to twin Samson 50w Studio Monitors
Twin Dell (E-IPS) U2311H 23.6" Screens
1920 x 1080 @ 60Hz
Crucial M4 SSD, archives on twin Western Digital Caviar Black WD2002FAEX, 2TB, 7200rpm HDD's, Samsung Ritemaster CD/DVD Burner...
OCZ 600w
Lian-Li PC8 acoustifoamed' aluminium tower
Scythe 140mm Zipang
Cherry PS/2 custom model
Lenovo USB laser "Thinkpad" Mouse
ADSL2+ @14Mbps downstream & Cat6 Gigabit Ethernet
NOD32
Opera
Silicon Dust HD Homerun Dual FTA (Ethernet) TV Tuners, Dray Tek Vigor 2850Vn router and 8x HP Gigabit Switch. Lian-Li CR26 Card Reader, Canon MF4430 iSensys laser printer/scanner.
A USB headset is essentially an external sound card, it in no way makes any use of a sound card whether onboard or actual card.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
If you have an internal soundcard as the OP does, and you can't select two output devices to stream two different audio feeds to - adding a USB soundcard would enable him to have two soundcards in effect, and achieve his aim ;)
Can't say as I've ever done it - however it's possible.
With a Logitech Clearchat USB headset I use it doesn't process the audio stream by itself, I have to set it as the device my internal soundcard points to. When I make that selection it will cut the audio from my 3.5mm jacks if, say, I already had WMP playing music and choose to use the USB headset in conjunction with an IM program for arguments sake...
W7 x64
1920 x 1080 @ 60Hz
OCZ 600w
Scythe 140mm Zipang
NOD32
Opera
That's why I said to use something other than WMP as I don't know of any setting in it that allows you to choose which audio device to use. Winamp I know does (and quite a few others have it as well) have the option to choose which of however many audio devices are installed/enabled,
the only reason the ATI HDMI output (from my video card) isn't in the Winamp dropdown is because as it says, not plugged in. If it was connected, then I could choose to use either my X-Fi or the ATI out.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
