Windows 7: CM6501 No sound solution
05 Jan 2010   #1
Hey all: I posted about this earlier and have seen many threads on it.
My problem began with install of WIndows 7 64bit. I had no sound whatsoever after install. I have ASUS M2n e SLI mobo with C media CM6501 USB integrated sound card.
I had no sound but could see the sound bar moving up and down when playing music. I tried installing the CM6501 driver and it installed but still no sound after restart. I tried opening the CM6501 icon in the task bar, but it would freeze my pc and I had to restart.
SOLUTION.
Install the driver for vista for CM6501 version 6.0.7.413. Restart your PC. When you restart, click on the CM6501 icon in the task bar. IT WILL FREEZE your pc for a while. I clicked it, then left my pc for 10 minutes, when I came back, the utility had opened. I changed the speakers from 2 to 6 or 8 channel and all the sudden had sound. Close it and enjoy. For some reason, it does not work with 2 or 4 selected. ANd the utility takes forever to open.
Thats it. Although, my subwoofer does not work with windows media, I can still play music. I did find that sound comes through my subwoofer in youtube, so it must be WMP issue. I think it will all get fixed when more drivers come out, but for the time being, its better than being without sound.
Hope this helps!!
 CM6501 No sound solution problems?
Similar help and support threads for: CM6501 No sound solution
Thx for the solution Chillout Room
Solved Realtek hd center and subwoofer having no sound solution Sound & Audio
Cm6501 Problem Sound & Audio
no sound at startup-possible solution Sound & Audio
