Windows 7: No sound.. please help!
10 Jan 2010   #1
Kitt
Windows 7 64bit
I installed Windows 7 a little while ago, and my sound hasn't come back. I've tried everything I can think of.. it's telling me my drivers are all up to date, but I think it's lying =/
I believe the problem has something to do with this..
I know I'm meant to have more than one in there, but I've no idea how to go about it =/ Also, it tells me that it's using the 'optical jack' whereas I obviously want it to be using the green jack.. Does anyone know what's going on, and how I can fix it, please?
Cheers!
-Kitt
PS.
My motherboard is an Asus M2N-MX, and I use the onboard sound.
11 Jan 2010   #2
Jonathan_King
Windows 7 Professional x64
Welcome!
What sound card do you have? Try using Speccy if you do not know.
11 Jan 2010   #3
stormy13
Microsoft MVP
Win 7 Ultimate x64
Motherboard,
ASUSTeK Computer Inc.
and uses the ADI1986A audio. Try using the Vista driver available from the above link.
11 Jan 2010   #4
NeroDevil
Windows 7 Ultimate x64 Service Pack 1
Hmm, idealy, the Windows Vista driver should be operational on Windows 7 for this.
Try and go to the manufacturers website and try to get a driver from there.
If they can't help, Google is your best friend.
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
narrator no sound - and sound vbs file no sound
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
System Event - Changing sound makes a sound, how to mute it?
Did my searching and couldn't find this one... When I modify the speaker volume using the "Volume Mixer" icon, it generates a sound. When I adjust using the "Speakers/Headphones" icon, it does not make a sound. I would like to mute the Windows 7 sound that happens when I adjust the sound,...
