Problem recording in audition 2.0
yigael
5:54 AM
Hello everyone, Im having problems recording from the Mic input in audition 2 with Win7 Ultimate 32bit on an audigy.
All audio plays fine, the microphone works fine in the volume test in the native win 7, but the problem happens when I try to record from the mic inside audition. It will read only one of the channels, the other will only show some really low input.
The microphone was working fine before installing win7 along with audition 2 under xp sp3
Any ideas??
Windows 7 Ultimae 32bits
I notice the current version is 3. Is that older V2 100% Windows 7 compatible? Vista and Windows 7 handle audio differently than XP and thus XP audio drivers do not work or work correctly in Vista/Win 7 and that may also be the case with the Audition V2 since it was working OK in XP and designed for how audio is handled in XP.
Also the mic input is mono, not stereo and if you are only seeing audio on one channel that could be the reason.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
the microphone was recording completely fine in stereo when I was running XP. I managed to get audition 3 and is the same, very low input from one of the channels
Did you run the Mic configuration wizard?
Right click on the MS speaker icon in the task bar.
Select recording devices.
Notice the "Configure" buttons made available when a device is selected... see if you have any options there.
Ap
Windows 7 Home PremiumIntel Core 2 Duo @ 3.00gHz4 GBATI Radeon HD 2600 XT
Assembled in my workshop
Gigabyte GA-P35-S3G
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
