Windows 7: cant fix sound distortion
12 Jan 2010   #1
hello, i have been looking around the inter-web-nets for about a week now, and i cant find anything that will fix the sound distortion problem im having.
i have an intel dp45sg board, q8200 quad core and integrated sound at the moment. i have installed/uninstalled/re-installed way to many different realtek/idt audio drivers and none of them fix the problem. every time i uninstall the sound from device manager and restart, the generic High Definition Audio Device gets re-installed.
if there is ANYONE that can help, this is driving me NUTS!!!
12 Jan 2010   #2
Windows 7 Professional x64
Rednecksville
Welcome!
How long has this been going on for?
12 Jan 2010   #3
i had windows 7 rc and did a clean install of real windows 7 last week.
the oddest part about it is, it was working perfectly fine in RC, then i had to move my computer desk and everything (room flooded) and put in a different room and thats when it started, still in RC. i thought doing a clean install would fix it, but no fix.
12 Jan 2010   #4
Rednecksville
If your room flooded, it is possible you have some damaged hardware. Either the sound card or speakers may need to be replaced. Try another set of speakers/headphones in your machine.
If they are distorted, try your sound card in another machine.
12 Jan 2010   #5
ha...i didnt even think of that /slap. i did try another set of speakers, same problem. as far as soundcard, its just the on-board card for now
i wouldnt think anything inside the case would be affected by the water, as it was on the hardwood beside the carpeted area. the wires were on the carpet, however, but everything else is working. ill try the headphones out, if i can find some.
12 Jan 2010   #6
Rednecksville
Your motherboard might be messed up. If you have another sound card compatible with 7, try it. Otherwise, you may need to replace your MB.
12 Jan 2010   #7
NOOOOOOOOOOOOOOOOOOOOOOOO thats a terrible idea! is there a way to test the MB? programs or anything? that is the only problem im having with it.
12 Jan 2010   #8
Rednecksville
I do not know of a way to test the MB. Perhaps the techs in the shop could, but you would probably be better off buying a new sound card and installing it in a PCI port.
I would look here. Just make sure it is compatible with Vista or 7.
12 Jan 2010   #9
awesome....ill try out a new sound card asap....ty for the help
 cant fix sound distortion problems?
Similar help and support threads for: cant fix sound distortion
Youtube Sound Distortion Sound & Audio
Lagging and Sound Distortion General Discussion
Windows 7 Sound Distortion Sound & Audio
windows 7 sound distortion Sound & Audio
