background program volume?
  1. Posts : 35
    Windows 7RC 64bit build710
    So if I am playing Left 4 Dead and listen to iTunes...my iTunes gets quiet automatically while playing Left 4 Dead. When I click on the iTunes it gets louder again and Left 4 Dead gets quiet. Is there any way to disable that feature?
  2. Posts : 910
    Win 7
    Go to control panel > Sound > communications tab and select "Do Nothing"
  3. Posts : 2,036
    Windows 7 Professional x64
    I'm not sur if this is what you're looking for but open the programs then right click the speaker icon and go to "open volume mixer" you can make any app any volume you want (or no volume) try it out it may work. Good luck.
