Windows 7: Volume not loud enough - how do I bypass volume limit?
04 May 2012   #51
antonio white
windows 7 home premium 32bit
loud music
13 May 2012   #52
windows 7 64 bit
I'm afraid I must say that XeRo is incorrect.
I use a hot swap drive bay, which quickly allows me to switch back and forth between Windows 7 and Linux.
I am able to achieve a much higher volume(through my headset) with Linux than I can with Windows 7, and this on the same mobo.
Note: This also is with the onboard sound instead of my aftermarket video card.
08 Jul 2012   #53
same prob - i have a quiet youtube video thats even super quiet at the max volume in windows, other videos are fine, how to go above limit in windows 7?
Search this Thread:
Advanced Search
How to limit max. volume windows 7?
Hi, in Windows 7, I want to limit the maximum volume level that can be used without touching anything in the speakers, only through software, so an inexperienced user only can reach a volume not too high while at the same time seeing that the volume is in 100%. Any ideas? I went to...
Encrypted Volume Check: Volume Info on \\?\Volume{X}Can't read
Encrypted Volume Check: Volume Info on \\?\Volume{X}Can Not Read Found this in my Event Viewer on each start/restart. I don't have any Volumes that I have encrypted. Is this malware? I've run everything prior to noticing including Windows Offline Defender. Not sure if this is even the...
General Discussion
Volume too loud
I keep reading complaints about Win7 volume being too low. Oddly enough, I find my volume too high. Is there a way to tweak the volume settings for more subtley at lower levels? I hooked up a set of speakers to my computer that does NOT have hardware volume controls or a remote of any kind. ...
Too loud volume
I have a Corsair Vengeance 1500 headset, and when I use it it's always too loud. Even when I turn the volume down to 1, it's too loud at times. I have tried it on 3 different computers, and it happens on all of them. I have gone to the control panel and tried to turn down all sound options, but it...
windows media center volume limit of 50????
Is there any way to change this? on my 7600 x64 the volume stops at ''50'' and is nowhere near as loud as the rest of the sounds from other programs.
Media Center
Windows 7 x64 volume too loud problem
Hi, I did not find any solutions to my problem from the forum so I decided to create a new thread about this. Problem details: -Volume is too loud, I have to set master volume to 1-5%, anything over that is too loud. I have had no problems when using windows vista or windows XP. My setup:...
