Volume not loud enough - how do I bypass volume limit?
Xax
7:33 AM
I like to listen to music loudly sometimes. I have both the volume mixer and my application's volume set to maximum levels, but it's not loud enough for my liking. Is there any way to increase the maximum sound volume in Win7?
Windows 7 Ultimate x64 RC1
I don't think they have altered the Volume limit in Windows 7 but you could always have a play with Graphic equalizer to see if you can increase it a bit there.
Windows 7 Ultimate Vista Ultimate x64Core 2 Duo E8500 3.16Ghz @ 3.8Ghz2x2Gigs Patriot PC2-6400 LLInno3D GeForce GTX260 216 SP
Home Brew
eVGA 750i FTW
SATA 150GB
SATA II 250GB
USB IDE 750GB Ext.
Liquid Cooling System
Logitech G15 Gaming Keyboard
Logitech G9 Gaming Mouse
Do you have external speakers? Works a charm if you dont ;)
Windows 7 Ultimate 32bit SP1
INTEL/D975XBX2
ATI Radeon HD 2600 Pro
Samsung SyncMaster 914v
1280 x 1024
One is not connected
Rocketfish 700 W
G.Skill Gigabyte Chassis
Standard PS/2 Keyboard
Microsoft PS/2 Mouse
DSL
Avira Internet Security
IE 11
ATI HDMI Audio
Yea...the onboard amplifier leaves a lot to be desired. It's not necessarily a Windows thing it's a Motherboard thing. Get externally amplified speakers and you are golden my friend.
Windows 7RC 64bit build710Intel Q9400 Quad: 2.66Ghz, 1333FSB8 gigs of OCZXFX 9600GT 512GDDR3 700Mhz Overclocked.
EVGA 750i SLI FTW
8 gigs of OCZ
Onboard 7.1
22" WS Samsung, 19" LG
1680X1050 and 1280X1024
Dual 1.5Tb Seagate Sata2
Coolmaster 600W
Ultra
two 120mm fans at each end, and one 80mm on the case window.
Razer Lycosa
Logitech MX Revolution
AT&T Uverse
external amplification is always a plus... but its not the solution
I have 400 watts (at 4 ohms) going to each of my front speakers, the aplifier weighs 100 pounds. Even with this kind of power (and I do admit, I should probably go for 1Kw some day) I find that the volume is lacking in windows.
I seek Bit Perfect audio, I want to bypass all the modification to the sound as it goes through the sound card, and especially the OS. I want myvolume to be controlled by my preamp, not by winamp, windows, or anything else.
Anyone have ideas?
Windows 7 Ult x64i5-520m8gb Kingston HyperXNVS 3100m
Windows 7 Ult x64
i5-520m
8gb Kingston HyperX
NVS 3100m
15.6'' LG Matte
Samsung 840
I primarily use headphones. My speakers have plenty of volume, and my headphones are fine most of the time, except when I'm watching something with lower-than-normal volume, or music that I want to listen to louder than usual.
Try enabling "Loudness Equalization" in your sound card settings, if available. You should see a bit of a boost in volume from that.
Windows 7 7201, Backtrack 4
Or maybe a hearing aid, after all that music louder than usual you might need it.
Vista Enterprise x64 SP1Athlon64 X2 6000+4GB 800MHz DDR2 OC-ZGeforce 8800GT OC
Athlon64 X2 6000+
M2N-e
Geforce 8800GT OC
X-Fi Extreme Audio
17" and 19" widescreen flatscreens
1280x1024 & 1440x900
600W Tagan
10Mbit down, 512Kbit up
Update your sound drivers with drivers from your sound cards Manf. Windows 7 installed its drivers for my Audigy 2 plat.... Sound was very quiet... I installed Creatives drivers... Volume half way up is much louder than the original drivers. Good luck.
Windows 7 64 bitAM2 5600+4 gigs Gskill 1066x1900xtx
Windows 7 64 bit
AM2 5600+
Gigabyte MA770-UD3
4 gigs Gskill 1066
x1900xtx
Audigy 2 Plat
I have the same problem - windows 7 audio is way more quiet then in vista! I will try the creative drivers instead of the built-in ones and will see...
Windows vista home premium and Windows 7RC1Q6600 @3.7GHzGeForce GTX275
Q6600 @3.7GHz
Gigabyte UD3R
GeForce GTX275
2x samsung spinpoint 750GB
Fortron Blue storm II
City Case
AC Freezer 7 pro
I know what you want. You want to put the volume to 150% not just 100%. Linux as be able to do this for over 10+ years and I have not find this in any version of windows to date.
In Linux you just click on the sound icon on the taskbar, then open the sound preferences, there you can put the volume passed 100% all the way up to 150%
I know what you saying, the volume in windows is just not that loud and you right. I have a duel boot laptop with win7 and Linux. Even at just 100% and not 150% (which Linux can do) it is all ready way louder than win 7 and can go louder.
100% volume in win7 is like only 60% to 70% volume in Linux. (This will very based on installed sound card. This is how it is for me.)
If you must have the volume louder you may have to install and use Linux. UNLESS there is a windows app that will do this for you, that I just don't know of.
I don't know way MS puts the volume limit so low.
PS: this is not the only resigns to get Linux. http://www.whylinuxisbetter.net/
Linux Mint 9 and windows 7
Yes, there is definitely a difference in Windows 7 overall output volume, I have a tri-boot system, Win-7, Win-XP & OSX-Leopard. Win-7's output volume is positively anemic compared to the other two. Probably something to do with leaving overhead for the DSP plugins, bad decision though. Microsoft should have released some kind of audio guide for the changes made, I've never seen as many complaints regarding an OS handling of internal audio.
Ap
Windows 7 Home PremiumIntel Core 2 Duo @ 3.00gHz4 GBATI Radeon HD 2600 XT
Assembled in my workshop
Gigabyte GA-P35-S3G
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
I have and idea - you can use ffdshow settings to boost volume while watching movies (if you have it installed - for example as a part of CCCP codec pack)
Q6600 @3.7GHz
Gigabyte UD3R
GeForce GTX275
City Case
AC Freezer 7 pro
dfx audio enhancer
Mate just use "dfx audio enhancer"... it's a type of plug-in that works for alll kinds of media players (WMP. Winamp, DivX, VLC media player). You can choose whether you want to listen on speaker or on headphones and what you want hear louder (only bass, vocals, or everything).
I used this on my old laptop which just didn't have enough volume. You can find this software for about 29 Bucks or just search the web until you find it for free.
Windows 7 Ultimate x64Intel I7 875K (liquid cooled)Corsair Dominator 1600Mhz (4 x 2 gigabited)Asus EAH5870 V2
Assambled it myself, but the heart of it is ASUS
Asus maximus iii gene
Asus EAH5870 V2
onboard (SupremeFX X-FI chip) & graphics card (ATI HD audio)
AOC 24 inch LCD
1080p
One Samsung F1 1TB (SATA) So nothing special
Corsair HX 750 Watt (modular)
Lian li v352B (mATX case)
Corsair H50 with just push airflow
Logitech Ultra Slim (no really that's what its called)
Logitech MX reveloutions
10 Mbps (according to ISP)
This is my first build!!!
VLC Media player will let you increase volume up to 200%.
windows 7 Home PremiumIntel Core i5 @ 2.27GHz 32nm TechnologyDDR3 4.0GBIntel(R) Graphics Media Accelerator HD
Acer Aspire 5741
Acer Aspire 5741 (CPU)
DDR3 4.0GB
Realtek High Definition Audio Intel(R) Display Audio
Generic PnP Monitor on Intel Graphics Media Accelerator HD
1366x768
Seagate 2.5" SATA 500GB
Synaptics PS/2 Port TouchPad
Microsoft Comfort Mouse 4500 (IntelliPoint)
This is possibly an update but on searching google, this thread was the top hit and the actual answer is not in here.
Control Panel > Hardware and Sound > Sound > Select Your Output on the Playback Tab > Properties > Enhancements Tab > Enable "Loudness Equalization"
I'm not sure if this will push the sound levels above a threshold but it should fix problems with things being too quiet at the OS level.
Just wanted to put an actual useful answer in this thread for future searchers.
Windows 7 Enterprise x64, Ubuntu 10.10, Windo...
Windows 7 Enterprise x64, Ubuntu 10.10, Windows Server 2003
That was it, thanks!
Windows 7 Home Premium 32bit
I am having the same problems with my windows 7 and the volume being quieter then it should be. But heres the catch, when i first installed the drivers for it from the Realtek web site. Now this isn't my main computer its my laptop although I NEVER use the built in speaker I always use my External speakers. My external speakers are the Logitech X-540 5.1 Surround Sound System. I did a fresh install when i first got the computer and downloaded the drivers from Toshiba's website, But also it does have Dolby Advanced Audio not sure it this would effect it or not but I have to have the volume at 100% on my laptop but I leave it there because I never use the built in speaker, but I have to have the volume over 50% on the speaker system to have a good volume level for comfortable listen. If any one could shine some light on this issue that would be great.
RitualJman
Windows 7 Pro 64-bitAMD BullDozer FX-4100 3.6GHz Overclocked to 4...16GB G.Skill DDR3Sapphire Radeon HD 6770 Video Card - 1024MB, ...
AMD BullDozer FX-4100 3.6GHz Overclocked to 4.51GHz
Asus SaberTooth 990FX
16GB G.Skill DDR3
Sapphire Radeon HD 6770 Video Card - 1024MB, GDDR5
Creative Labs SB X-FI Titanium Fatal1ty Champ PCIe
Viewsonic VX2025VM & Acer P191w
Viewsonic VX2025VM 1680x1050 & Acer P191w 1440X900
Crucial M100 512GB SSD
Seagate 2TB
CORSAIR 860W 80 PLUS PLATINUM Certified Full Modular Active
NZXT Phantom 410
CoolerMaster Siedon 240XL Water Cooling
Logitech G510 Gaming Keyboard
Razer Abyssus Gaming Mouse
Ping: 4Ms Download: 88.25Mbps Upload: 91.00Mbps
Avast Internet Security
1. Thermaltake BlacX 5G Black USB 3.0 HDD Docking Station
2. NZXT Aperture M 5.25" Internal Card Reader 2x USB3.0
3. Dazzle Multimedia DVD Recorder HD & Video Capture
4. Razer Sabertooth Elite Gaming Controller
5. Xbox 360 Guitar Hero 3 Guitar (USB2.0)
6. Microsoft LifeCam HD-5001
6. Plantronics RIG Stereo Headset + Mixer
Some audio software /cards come with a setting 'nightmode' - make sure you are not stuck on that!
WIN7 Ultimate 64bitAMD FX8150/Trinity A10-5700G-Skill 2400 x2 @ 1866 (both pc's)Sapphire (factory OC version) AMD 7770
D.I.Y.
WIN7 Ultimate 64bit
Asus Sabertooth v.1 /Asus F2A85-M Pro
onboard
T260 Samsung
Western Digital Sata 2TB/1TB Caviar Blacks
Buffalo 1TB usb (excellent drive)
Be-Quiet 700W E-9/Be-Quiet 550W E-9(E-9 = built by FSP)
Antec P183/Antec P180mini
x2 Xigmatek SXHH7-U01 + C-Master R4-EXBB-20PK-R0 120mm Fans
Cherry
MS Explorer 3.0
LG Blu ray combo
Pioneer 207D/208 Blu ray burners
Windows 7 Ultimate 64bitIntel i7 3770K16GB DDR3 1333 Corsair XMS3XFX HD6950 2GB EyeFinity
HAL-9000
Intel i7 3770K
Asus Sabertooth Z77
Logitech G35 & Sennheiser PC135 & VIA HD
23" HP 2310e, 23" Samsung B2230, 21.5" Viewsonic
5760x1080
16TB of Storage
128GB & 256GB Crucial M4 SSD's, 2X 1TB WD Black, 3x 2TB WD, 3x 2TB Samsung F4, 1.5TB Seagate, WD 500GB,
Antec True Power New 650watt
Cooler Master HAF-932
Corsair H60 Hydro Cooler, 3x 230mm Fans, 2x120mm Fan
Logitech G15 and G13
Logitech G700 Gaming Mouse
50/10 Mbit
Speakers : Alesis M1 Active Mk2 Studio Monitors , APC RS 1200 UPS, HP 4500DN Color Laser, HP P1006 mono Laser, Kodak 8500 Dye-Sub, Epson 1280 inkjet, Epson Worforce 610 MFC
