No sound after sleep mode
lokem
7:19 AM
Hello,
I am having problems with my onboard sound not working after my computer wakes up from sleep. I need to restart the computer to get any sound in the speakers again.
Note that this is regarding my motherboard in which I have my speakers plugged in. My headset works fine after sleep, they are plugged into a Creative SB Audigy sound card.
When the onboard sound is not working after sleep, I can not even start playing music, as if I there were no sound card installed.
I have found some "solutions" in various forums, but it haven't helped me (and most of them was regarding specific laptop models anyways).
Please help me if you can.
Thanks!
EDIT: SOLVED, READ BOTTOM POST
Windows 7 Professional 32-bit (6.1, Build 7600)Intel Core 2 Quad @ 2.83GHz4096MB RAM (2x 2GB PC6400 DDR2)NVIDIA GeForce 8800 GTS 320MB
(Custom built system)
Asus P5Q Turbo
Creative SoundBlaster Audigy
Samsung SyncMaster P2350
Western Digital VelociRaptor 10000RPM SATA
Zalman 600W
Antec Performance One
4x Noctua fans
Hello,
Thanks!
Do the headphones work with the intergated card? Have you considered plugging the speakers into the working card and the headphones into the intergrated one?
Win 7 pro 64-bit, Ubuntu 9.10 64-bitIntel Core 2 Duo 2.60 Ghz4 gb ddr2 667 MhzNVidia Geforce 9400 GS 1 gb ddr2 550 mhz GPU
Acer Veriton m261 (modded)
Whatever came with the system
4 gb ddr2 667 Mhz
Intergrated
samsung SyncMaster 2494 24"
1080p
80gb - IDE
750gb - SATA II
whatever came with the system
Apple Aluminium (Awesome)
Some awesome Dell mouse, really good.
100mbps
Hello,
I tried changing the headphones with the speakers, and also downloaded the latest drivers from Creative's website and restarted the computer. After this, I could hear sound in both speakers and my headset after a sleep mode.
I have no idea which step solved the problem, but anyway, thanks for the help! It is greatly appreciated! Keep up the good work. ;)
Asus P5Q Turbo
Zalman 600W
4x Noctua fans
