Creative Sound card
  1. Posts : 215
    Windows 7 Professional SP1 64 bit
    Creative Sound card
    I've got a Creative Sound Blaster X-Fi Xtreme Audio. I have 2/2.1 speakers. What jack in the back of the card should I be in? When I run creative diagnostics I hear the left and right speaker but not my center speaker. With the 2/2.1 speakers do you stay in the green jack?
  2. Posts : 4,280
    Well with my 2.1 speakers I do. What speaker system are we talking about. Manufacturer and model number that is. Thanks. Fabe
  3. Posts : 4,517
    Perhaps im mistaken, but i didnt think 2.1 had a center channel.
    I Thought 2.1 means << Left -- Right -->Sub >>
    Which should just connect to the green output on the card & the speakers have the Sub crossover built in.
  4. Posts : 6,618
    The speaker leads should be color coded, and if you applied the decal that came with the sound card, the ports on it are also. Match the colors.
  5. Posts : 215
    Sorry for the delay in responding. The tip is colored green so I put it in the green jack. Thank You to everyone for your responses.
