No sound
  1. Posts : 2
    window7 ultimate
    No sound
    I just installed Windows 7 and I lost my sound. It work fine with Windows XP. I have fairly new motherboard ASUS® M4A785TD-V EVO. I tryed windows 7 drivers and it thinks it is playing sounds but its not. I unistalled them tryed the ones off my disc that came with my Motherboard, it did the same thing. Then i got I got updates for windows and try it again. With each I tried Head phones and speakers also tryed the front and the back and the side speakers and no worky. I have check the mixer settings. I looked in Bios and it is set for onboard. I tried the hdmi setting too. My bios is version 211 and say date 7-08-09. Yeah i have the audio icon at the bottom, when i play music then green bar goes up and down as if its playing but just nothings coming out the speakers? I dont know why the computer thinks the sound is working?
    I now have no sound, can anyone help me?
    I have made sure they are plugged in the right slots and still nothing?
    I have
    Sound Card ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO
    Can anyone please help?!!!
  2. Posts : 304
    Operating System Microsoft Windows 7 Ultimate Build 7600
    Hi PokerPro!
    I would check your sound drivers first if I were you.
    Your motherboard needs the VIA Audio Driver 6.0.1.7400.
    You can get it here: Download Asus M4A785TD-V EVO VIA Audio Driver 6.0.1.7400 Driver for Windows XP / Windows Vista / Windows XP X64 / Windows Vista64 / Windows 7 / Windows 7 x64 - Softpedia
    Give that a try and see if it solves your problem.
    Hope that helps.
  3. Posts : 1
    Hello everybody..
    I had a problem where my laptop DELL INSPIRION 1420 that was upgrade to WINDOWS 7 not working properly on it speaker and webcam.
    The speaker totally does not work at all bevause there was no sound appear at all although I already set the loud sound.
    About my webcam, the driver is working properly but the webcam still cannot use. I think the software was not install yet because I dont find any compatibility software for webcam in Windows 7.
    FYI: I already check my device manager and the result shows all device install properly.
    Please help me solve the problems because I don't find any solution yet for this matter.
    Thank you.
