No sound through 5.1s... only headphones
  1. Posts : 5
    Hi guys,
    I just built my new computer (Gigabyte mobo p55-ud3r + 4gb Ram + i5), but I can't get the sound working with my old 5.1 speakers, which worked fine on vista before. Thing is, when I connect my headphones, the sound works.
    Should there be a difference? I can't even check to see if the surround sound speakers work anymore to eliminate a possible problem.
    Thanks for your help!
    cody
  2. Posts : 13,354
    Windows 7 Professional x64
    Hello,
    Do you have another computer you can try the speakers in?
    ~JK
  3. Posts : 5
    Unfortunately not. I tried to install my old sound card (Creative Live! 5.1), but of course the drivers are not available for Vista and Win 7. I ended up going out and buying new speakers, just to isolate the issue, and the new ones worked, so I think it must have been the 8 year old ones I was trying to use.
    Thanks for the tip though!
  4. Posts : 13,354
    No problem. Anything else we can help you with?
