5.1 surround sound problems with SoundMAX
austt003
12:55 AM
ive just installed windows 7 x64 and the windows update has installed the driver for my sound card but i cant get full surround sound.
everytime i restart and login i have to say whats connected into the 3 jacks but when the sound does start it only comes through the front 2 speakers, centre speaker and the sub.
when i try to open the SoundMAX program it says "SoundMAX required windows vista. This application is shutting down.
does anyone know where i can get a x64 version of SoundMAX for win7
Windows 7 x64AMD Phenom II 955 3.2ghz2x2Gb 1066 Team Xtreem DDR2NVidia GeForce 7900 GTX
Windows 7 x64
ASUS Crosshair Formula II
Supreme FX II
On many systems, SigmaTel drivers from the motherboard vendor are required for the sound to work correctly. Windows installs a generic SoundMax driver (SoundMax is now called IDT) and in some cases the Windows drivers do not work or work correctly. I'd check the ASUS site to see what they have as a starter.
On some devices Vista drivers will work with Win 7, since Win 7 is basically "Vista improved". You may have to install the SoundMax drivers in the Vista compatibility mode to get them working if there are no Win 7 specific drivers available.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
