Windows 7: Creative's Sound Blaster X-Fi Xtreme Audio PCI Express
28 Jan 2010   #11
Win 7 Ultimate x64
Etobicoke, Ontario
Try the modded driver set from #1 here,
SB P17X Series Support Pack 2.0 (07/31/2009) - Aud... - Creative Labs
29 Jan 2010   #12
Windows 7 Ultimate
"Setup is unable to detect a supported product on your system. Please ensure that your product is proberly installed before running this setup program. Setup will exit"
Also tried compatibilty mode with Vista and XP. Also tried to run it as an administrator. Nothing.
30 Jan 2010   #13
Windows 7 Ultimate
Any other ideas? All I want is to get my microphone to work.
Danke!
01 Feb 2010   #14
Windows 7 Ultimate
**BUMP**
01 Feb 2010   #15
Win 7 Ultimate x64
Etobicoke, Ontario
Give this a try,
Creative Worldwide Support
if it installs it will give you the audio console like the one I posted, and then hopefully you can configure the mic.
01 Feb 2010   #16
Windows 7 Ultimate
Thank You very much! It worked! Thank You!!!
Case closed.
01 Feb 2010   #17
windows
i have this same card. all you should have to do in install the card, install the drivers / software for vista from the disk that came with it, do not do the auto update, plugin the mic into the righthand plug, your speaker in the plug next to that. you should not have to make any adjustments other than the audio levels in the creative control counsel.
07 May 2010   #18
Im very sorry to bump this topic.. but i got the same problem and the link that stormy13 gave doesn't work anymore.
Anyone that can give me that link?
// edit:
Found it.. but i get an error at launching the program.
It says that i dont have compattible audio-devices and that i need to close the program and click on OK. Can't do more then that.
14 Sep 2010   #19
Windows 7 Professional- 64
I just wanted to say thank you to Stormy 13. It is hard to believe that you have to install all the software just to change a setting from Line-in to Microphone. Your comment and illustration saved me a LOT of ADDITIONAL time. Finally finding the installation disk helped too.
25 Nov 2010   #20
stormy13 i have problem with my sb card - probably i m doing sth WRONG, cause im completly green with any drivers. so i have win 7 x64 and when i'm installing Your drv there are errors : myimg.de - kostenloses Bilderhosting
could u guys tell me step by step what to install / uninstall to make the MIC ENABLE ?
edit: or that error : http://www.myimg.de/?img=Nowyobrazmapybitowejf4937.jpg
pls help.
 Creative's Sound Blaster X-Fi Xtreme Audio PCI Express problems?
Similar help and support threads for: Creative's Sound Blaster X-Fi Xtreme Audio PCI Express
Creative Sound Blaster X-Fi Xtreme Audio PCI - microphone problem Sound & Audio
Sound Blaster X-Fi Xtreme Audio 70SB104000001 Sound & Audio
Sound Blaster X-Fi Xtreme Audio / Creative.com Sound & Audio
Creative sound blaster X-FI audio card PCI Express - Options Missing Sound & Audio
Creative Sound Blaster X-Fi Xtreme Audio Sound & Audio
