Windows 7: Creative's Sound Blaster X-Fi Xtreme Audio PCI Express
05 Jul 2011   #21
Windows 7 Professional 32-Bit
Quote   Quote: Originally Posted by Beach View Post
Yea I figure that would help IF I had that kind of a control panel
All I have is what I posted on my picture... And on that control panel there is no FlexiJack tab tag. Any ideas? I mean I did download the latest drivers and some other stuff...
Can you post a picture of your sound card? So i can get The details.
02 Aug 2011   #22
windows 7 Ultimate 64bit
Stormy13 you are a legend thanks mate!!! I have had nothing but pain since I installed this card and your post made the pain go away,it's taken me bloody ages to fix this issue and your exe fixed everything. Your a ****'n champion!! ON YA MATE
Search this Thread:
Advanced Search
Sound Blaster X-Fi Xtreme Audio: Speakers pop when I click some things
I put in a Creative Sound Blaster X-Fi Xtreme Audio (PCIe), installed the latest driver from Creative, found here: Creative Worldwide Support (1.04.0000, released 30th June, 2009), and it seems that whenever I click things that make noise (a good example being the volume slider in the system tray),...
Creative Sound Blaster X-Fi Xtreme Audio PCI - microphone problem
Hello there. Yesterday i've installed this sound card and everything works fine but no microphone. I can see it in control panel but it doesn't work. Mic is fine as i was using it before. I have Win 7 64bit. If you have any idea what can cause the issue please help, if nothing will work i will...
Sound Blaster X-Fi Xtreme Audio 70SB104000001
Hi guys I treated myself to a new pc but the only thing missing is a soundcard. Im looking at Sound Blaster X-Fi Xtreme Audio 70SB104000001 Creative Labs Online Store (UK) | Sound Blaster | Buy Creative PCI Express X-Fi Xtreme Audio I am running windows seven home premium 64bit and i...
Sound Blaster X-Fi Xtreme Audio /
Ok, so I read the stickied topic about the X-Fi Xtreme Audio driver, as I think this maybe a part of my computers less-than stable condition after recent Fresh Installs of Windows 7 Home Premium 64bit. I got 2 things... 1) When I install Drivers off my CD, I get a SpiRunE.dll error about a...
Creative sound blaster X-FI audio card PCI Express - Options Missing
Hi, I am hoping someone has the answer for my problem as I have searched everywhere and tried a lot to fix the issue. The issue I have is that I don't have any Bass control or Bass Boost options available. I have tried removing the drivers many different ways even in safe mode and even used...
Hi, im running windows 7 (7100) 32 bit. Ive got Creative Sound Blaster X-Fi Xtreme Audio in, ive downloaded the xp, vista and 7 beta drivers from creative, they either say driver version not found OR they say the device isnt plugged in properly, which it is having run it with xp. The only thing i...
