No AUDIO OUTPUT DEVICE IS INSTALLED
carlalopes
7:16 AM
No AUDIO OUTPUT DEVICE IS INSTALLED, this is the message l got on sound icone since l installed windows 7
l have downloaded it several time the latest one it shows on control panel but not on device manager, l guess this is not really installed but l keep installing it and restat the laptop after ward , howeve rnothing happens
the sound work only on my external speaker, but not on the external microphone - micro NOT WORKING AT ALL EITHER
after l installed windows 7 - l got a message on the task bar saying that PCI memory card was not installed l went to toshiba and downloaded the utilities driver again so PCI memory is installed and nothing wrong shows on device manger this sounds ok
, before to instal it on device manager was a notice that some 'basics card were missing'' now there is no yellow triangle there so l gues is ok
however does not show realtek installed on device manger no sign of it there- so l cannot update it or even unistal as nothing shows there
this is a satellite U 300 model- used to have windows vista...
lm tired of googling it and have clue how to sort it out.. l have downloaded several other REALTEK or any card sound , installed those that are accepted but nothing works on it...
please can any one help me with this issue
my email
many thanks in advance
Carlavent
windows7PCI
sattelite U300
windows7
PCI
REALTEK
LCD
160 HD
Hello Carla,
Welcome to Seven Forums.
First off it is not wise to put an email address in your posts. It will attract tons of spam.
Was this an upgrade install or a clean install of Seven?
Gary
Vista Ult 64 bit Seven Ult RTM x64Intel Core2 Quad Q6600 2.40 gigahertzCrucial Ballistix 4x2GB PC2 6400NVIDIA GeForce 8600 GTS 256 MB
Dell XPS420
Creative SB X-Fi audio
HP w2207 + HPvs15
1680x1050 + 1024x768
2-WD5000AAKS-500 GB
WD5000AAV-500 GB external
Microsoft Comfort Curve
MX Revolution
Experience Index=5.5
my email
[email protected]
Carlavent
Hi and welcome
After you installed Win7 32 bit on your laptop did you go to the Toshiba website and install the Win7 drivers for your new install?
Link
Toshiba Software Installer for Windows 7
Here is also a link for the Audio drivers for Win7 from Toshiba.
http://www.csd.toshiba.com/cgi-bin/...300-ST3091&selCategory=3&selFamily=1073768663
Windows 10 ProIntel i5I'm old and lost a few chipsYup
Windows 10 Pro
Intel i5
I have a fatherboard
Yup
Yup
Samsung 32" UHD
3840 x 2160
Samsung 860 EVO drives
450 Watt and some fans that blow
Small tower
Yes I am cool. lol
Who needs a keyboard?
Logitech Laser G7 wireless
Zippy fast UP and DOWN
I got a shot
The new Improved EDGE 2020
this is a new windows 7 bought on amazon , just installed in this computer...
2 days ago i reinstalled again realtek after several time it worked then in the night i tried to play songs on windows media plyer the sounds cracked no more sounds is there again, l have installed it again several time and do not work at all
i install it from toshibaweb site the one specific to this notebook but once i click to instal after extracting it simply desapear does not come any more step to continue the installation l have tried it several time and nothing...so frustrating
thanks for helping
windows7PCI
sattelite U300
windows7
PCI
REALTEK
LCD
160 HD
thanks for helping
Did you read all the documents from the website about upgrading to Win7?
Did you follow all the steps?
What version of Win7 are you running?
Is it a 32bit or 64bit install?
Was this an upgrade install or a Full install from Vista or from WinXP?
Can you tell me what version drivers did you use from the website?
Windows 10 Pro
Intel i5
Yup
Yup
Samsung 32" UHD
3840 x 2160
Small tower
Yes I am cool. lol
I got a shot
Thanks again
I had vista, and installed a full version of windows 7 32bit, it is in a cd from a retaller, l jave run it twice already and nothing happens, it did work at some point but then cracked after listening to music from my SD card
yes l read all the guide from toshiba before installing it, and did follow it well l suppose l did
thanks
windows7PCI
sattelite U300
windows7
PCI
REALTEK
LCD
160 HD
Thanks again
thanks
Maybe someone elese has some suggestions. The only thing I would suggest is go into the Control Panel, Device manager and remove the sound card and reboot while hooked up to the internet and see if Win7 installes the proper drivers.
Hope you find a solution.
Windows 10 Pro
Intel i5
Yup
Yup
Samsung 32" UHD
3840 x 2160
Small tower
Yes I am cool. lol
I got a shot
thanks again
but as l said before on device manger there is no sounds card, this option is now on shown there, only when l use the USB external sound but i have done it and looks like the option is only for the external sound as when l disconect it from the PC the sounds card desappears again, that is my problem why it show on control panel that is installed but does not show on device manger neither on all programs when l click on start - all programs,,,
if any one can help,
grata
windows7PCI
sattelite U300
windows7
PCI
REALTEK
LCD
160 HD
i am getting no AUDIO OUTPUT DEVICE is installed on my device,i have a hp pavillion laptop.please help for the problem to remove it.
win7 32 bit
win7 32 bit
