SRS Sandbox sound issues, no voice...
Hello all! So last night I started having some issues playing my .mkv files for some unknown reason. First Media Player Classic HC would not even play any .mkv files, so after some frustration and uninstalls/reinstalls I finally got it playing, however with the sound there is an issue that I can't seem to fix. I've been using Sandbox lately because the sound difference is astounding through my 5.1 but it only works properly on the TruSurround XT setting. When I switch it over to WOW HD which I prefer, I can hear all the background noises and effects and music and whatnot but when someone talks, you can't hear their voice...like at all. I did turn it up all the way during dialog and was able to get some robotic sound faintly heard with my receiver and computer volume maxed out. If i switch it back to TruSurround XT during playback everything plays as normal, but I prefer the WOW HD sound instead. I am using the latest version as far as i know 1.10.2.0 - and have uninstalled/reinstalled it as well. Also I do have to use VLC to play .mkv files now as Media Player HC will play them but the volume is drastically low for some reason... any help would be MUCH appreciated! .. Oh yeah also in VLC when Im playing a movie, Transformers for example and switch the option under "Audio Device" to stereo, everything works fine, but of course thats only 2 channels, if I switch it back to 5.1 then thats a no go...
