SRS Sandbox sound issues, no voice...
Bodom
12:11 PM
Hello all! So last night I started having some issues playing my .mkv files for some unknown reason. First Media Player Classic HC would not even play any .mkv files, so after some frustration and uninstalls/reinstalls I finally got it playing, however with the sound there is an issue that I can't seem to fix. I've been using Sandbox lately because the sound difference is astounding through my 5.1 but it only works properly on the TruSurround XT setting. When I switch it over to WOW HD which I prefer, I can hear all the background noises and effects and music and whatnot but when someone talks, you can't hear their voice...like at all. I did turn it up all the way during dialog and was able to get some robotic sound faintly heard with my receiver and computer volume maxed out. If i switch it back to TruSurround XT during playback everything plays as normal, but I prefer the WOW HD sound instead. I am using the latest version as far as i know 1.10.2.0 - and have uninstalled/reinstalled it as well. Also I do have to use VLC to play .mkv files now as Media Player HC will play them but the volume is drastically low for some reason... any help would be MUCH appreciated! .. Oh yeah also in VLC when Im playing a movie, Transformers for example and switch the option under "Audio Device" to stereo, everything works fine, but of course thats only 2 channels, if I switch it back to 5.1 then thats a no go...
Windows 7 UltimateIntel Q82004Gb OCZ Flex XLCNvidia GeForce 7800GTX (2)
Windows 7 Ultimate
Intel Q8200
MSI P7N-SLI
4Gb OCZ Flex XLC
Onboard
32" Sharp Aquos
...too many
700 Watt Rocketfish
Anyone have any ideas or suggestions? It would be much appreciated
Windows 7 Ultimate
Intel Q8200
MSI P7N-SLI
4Gb OCZ Flex XLC
Onboard
32" Sharp Aquos
...too many
700 Watt Rocketfish
Hi there Bodom,
I had a very similar problem a long time ago and as such I cannot remember clearly how to resolve it. My problem was that voice-overs in Starcraft could NOT be heard over my speakers. It appeared to be a problem of how SRS distributed audio channels over my speakers.
What I did to figure out this problem was go to Control Panel, then Hardware and Sound, then open 'Manage audio devices'. From there, I selected 'Configure' with
CPanel said:
Speakers
SRS Audio Sandbox (WDM)
Default Device
highlighted, and changed it so it matched my speaker configuration. In my case, it was on 5.1 Surround before so I changed it to Stereo because I have a 2.1 speaker setup. You would do the opposite [Stereo ==> 5.1 Surround]. Progress through the setup and finish it.
Then, I restarted my computer and opened up my SRS Audio Sandbox control panel and selected WOW HD (I prefer that too) and changed my speaker type to 'Stereo' (change yours to 5.1 Surround).
Then, it magically worked!
I'm sorry but that's all I can say because that's how I solved a similar problem of my own. Let me know if it works and if it doesn't, perhaps a more experienced person can assist you.
Windows 7 Ultimate x64Intel E8500 Core 2 Duo 3.16Ghz (Stock Speed)2 GB DDR2 800 PC2-6400 (Apacer Technology)ATI HD Radeon 4670 1GB Discrete Memory
MICRO-STAR INTERNATIONAL CO. LTD
Intel Deluxe Intel G31 chipset motherboard
Integrated Sound Card Realtek HD 5.1 - ALC888
Asus 22" LCD Monitor VK222H
1680x1050 Native Resolution (through HDMI)
500GB SATAII Harddrive
Deluxe Mini ATX Case
Stock Intel Cooling (fans on CPU, chassis, GPU and front)
Dell USB Entry Keyboard
Dell Generic Mouse Pointer
Optus Cable - 9Mbps Average
U have to set Your default device in Your relevant control panel. From that on, U're good 2 go!
Win 7 Ultimate X64QuadCore Intel Core 2 Quad66004096 MB (DDR2-800 DDR2 SDRAM)NVIDIA Geforce 9600GT
Built
Win 7 Ultimate X64
ASUS P5K Pro
ASUS W222 U
1680 X 1050
HD: SAMSUNG HD753LJ ATA Device (750 GB, 7200 RPM, SATA-II), 2. drive - SAMSUNG HD103UJ (931 GB),
External drives: 1 x 120 GB + 1 x 100 GB External WD - drives (WD + Samsung) + 2 x 250 GB External HDD (WD)
Chieftek
Logitech MX 450
15 MB/s / 1 Mb/s
U have to set Your default device in Your relevant control panel. From that on, U're OK!
I'm sorry but could you be a bit more specific?
I believe his problem is that with a specific sound setup in the SRS Audio Sandbox control panel, he is only capable of hearing the channels for music, background noises and whatnot but not voice.
