Windows 7: Text to Speech Audio Problem
27 Jan 2010   #1
steve4peace
windows 7 64 bit
My 5.1 sound system works fine with all sound applications that I have tested except the text-to-speech program. When I run text-to-speech, I only get muffled sounds from my center speaker and subwoofer. I have checked all sound settings that I can find, including the text-to-speech audio settings in Control Panel, but to no avail. I need help.
Steve
02 Feb 2010   #2
steve4peace
windows 7 64 bit
This problem has been corrected.
Using built in text to speech function
I would like to use the text to speech function built in to Windows 7 to have my computer read Word and PDF files aloud. I can find the place to select the voice and reading speed, but can not figure out how to activate the text to speech function to read my documents. I should mention that I...
Installation & Setup
Can't use additional voices for Text to Speech using Microsoft Speech
Hi I'm trying to install additional voices for Windows 7 narrator and other Text to Speech Programs. I have downloaded and installed this: Download: Microsoft Speech Platform - Runtime (Version 11) - Microsoft Download Center - Download Details and then few of these: Download: Microsoft...
General Discussion
Text to Speech Shortcut - Create
How to Create a Text to Speech Shortcut in Windows 7 This will show you how to create or download a Text to Speech shortcut that opens to this tab in the Speech Properties window. You can also Pin to Taskbar or Pin to Start Menu this shortcut, or move where you like in Windows 7 for easy...
Tutorials
Text to speech for Windows 7
Is there any text to speech in Windows 7 ?
Text To Speech Problem
My 5.1 sound system works fine with all sound applications that I have tested except the text-to-speech program. When I run text-to-speech the narrator will read the text, but I only hear a faint muffled voice coming from my center speaker and subwoofer. I have checked all sound settings that I can...
Software
Speech/audio problem
Ok, haven't had hardly any problems with Windows 7 and i love it. I can't stand going back to vista. I have one problem though. Every time i open up Team Speak, Ventrillo, or Xfire the screen freezes for about 45 seconds and then it lets go and lets me continue on. then if i mess with settings it...
Drivers
