Changing system default VST directory in W7
Hello everyone,
I've run into a little problem. I need to change the default VST directory on my system, but it seems the method of doing so is different from Vista and XP. You used to be able to change it in the registry. Does anyone know how to do it in 7?
Reason for this change is the fact that I have quite a few VST plugins installed, but many of them are incompatible with Adobe Premier and Media Encoder, among others. Looking back, I should have installed effects and instruments in separate directories.
Any help is greatly appreciated, Thanks! :)
