Solved Sound Blaster X-Fi Xtreme Audio 70SB104000001
Cyrus01
2:34 AM
Hi
Im looking at Sound Blaster X-Fi Xtreme Audio 70SB104000001
i was wandering if anyone had any advice on this card. i can't see it on the seven compatiblity site but Creative has windows seven drivers to download.
I was looking at the PCIe x 1 version as i have either a PCIe or PCI slot availble.
Hey there Click your Windows Orb and In search bar Type Device Manager hit enter then find where your card is listed if it is listed then right click it then update drivers if it finds it and installs it then you should be done if not then Power down PC Pull the card out then Look to see if your card slot is dirty or the pins if they are both clean then it should be in your device manager.
Windows 7 Professional 32-BitCPU Type DualCore Intel Core 2 Duo E6600, 240...Total 3326 MB ( 3 GB)NVIDIA GeForce 9600 GSO
Microsoft Gigabyte
CPU Type DualCore Intel Core 2 Duo E6600, 2400 MHz (9 x 267)
Gigabyte GA-G31M-ES2L v2
Creative SB Live! Value (CT4830) Sound Card
Emachines E19T6W HD-Ready Monitor
Drive #1 - ST3500418AS (465 GB) (SeaGate)
Black Edition Mini ATX Power supply Rating at 550 Watts
Mini ATX Tower
Standard Cooling
