Reinstalling Base System Device driver -- please HELP!
  1. Posts : 58
    Windows Vista Home Premium
    My Dell Inspiron 1521 laptop's built-in microphone doesn't work anymore after I installed Window 7.
    I followed suggestions to uninstall the Audio device driver and to reinstall.
    I uninstalled the Audio device driver and now my "Base System Device" doesn't have a driver. I troubleshoot and try to let Windows fix the missing driver problem but it failed.
    Problems found
    Base System Device doesn't have a driver (not fixed)
    Hardware changes might not have been detected (Detected)
    How can I get my Base System Device drivers?
    Many Thanks...Mimi
  2. Posts : 1
    Wibnows 7
    I am having the same problem help us. . .
    I use my usb to back up some of the important files I have.
    and the problem is this base system device driver, only the issue is
    because of this usb is not shown on mycomputer. . .
    tell as what to do with this base system device driver. . .
  3. Posts : 5,056
    Base system drivers are usually card reader drivers- Ricoh or TI or whatever. Download from your models support website.
