no sound on my right earphone
mie333
5:58 AM
URGENT!no sound on my right earphone
i have sonicgear earphone..my earphone working fine about three month but today it suddenly got a problem..my right earphone got no sound,but in left it still got a sound..for the first thought,i think mayb my earphone itself got a problem,but when i try plug it on others pc and laptop,both right n left side is working fine..so i start to realize that my earphone still in good condition but mayb there is some sound setting i need to adjust.i already try to set it to default but still i got the same prob,only my left got a sound .. and i already check in my device manger,still there is no sign that i missing my sound driver..so actually what is my prob?can anybody help me to solve this problem..plz
I USE realtek ac 97 audio driver..
Microsoft Windows 7 Ultimate x64 6.1.7601 Ser...Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz4.00 GB Dual-Channel DDR3 @ 665MHz (9-9-9-24)Intel(R) HD Graphics Family version=8.15.10.2353
Satellite E300 / PSE30L-009007
Microsoft Windows 7 Ultimate x64 6.1.7601 Service Pack 1
Intel Corp. Base Board Product Name (CPU1)
onexant SmartAudio HD, Intel(R) Display Audio version=6.14
1366 x 768 Pixels
625GB TOSHIBA TOSHIBA MK6465GSXN (SATA)
e-view
NETWORK CARD
-HUAWEI Mobile Connect - 3G Network Card version=6,0,1,279
-Intel(R) Centrino(R) Advanced-N 6230 version=15.3.1.2
-Atheros AR8152/8158 PCI-E Fast Ethernet Controller (NDIS 6.20) version=2.0.15.16
Well, check your balance and make sure it isn't panned left. Also try instead of plugging into your rear input plug it into your front panel input to rule out the jack.
Windows 7 Home Premium x64AMD Phenom II X4 9458 GB G-Skill 1.5v DDR 3 1333Mhz(2) MSI 512MB GTS 250 SLI
Home built
ASUS M4N98TD EVO AM3 NVIDIA nForce 980a SLI
Soundblaster Audigy 2 platinum
Samsung 2255BW 22"
1650 x 1050
2 WD 250GB 7500RPM
Antec TP-750. The ultimate bang for the buck PSU
Raidmax
Sycthe Slipstream cooling fans(4)
Zboard Merc
Logitech MX-518
3MB
LG Blu-Ray/DVD combo drive/LG DVD-RW w/ lightscribe
well sir,can u please specified what u talking..where can i find that balance setting..n what u mean with 'rear input plug n front input plug'..i use desktop, i think i just have one input plug at the rear of my cpu
1366 x 768 Pixels
e-view
NETWORK CARD
Most newer desktops have jacks in the rear via onboard mother board or a seperate sound card as well as a set of jacks on the top of case or on the front of case some where. Generally there are accompaing usb ports as well in the front panel. Look for those. If you click the arrow in the notification area you should see your audio icon. Right click it and click the main board app. This is where you check your settings. Also check to see if there is a driver update.
Windows 7 Ultimate 64 bitAMD Phenom II X4 965 Black EditionGSkill 4 X 2 GB PC 8500XFX Radeon HD 6790 D
Custom built
Gigabyte GA-MA790X-DS4
On board RealTek HD
Dual monitors:Samsung SyncMaster S20B300
1600 X 900
Seagate Barracuda 1TB (primary)
Seagate Barracuda 2 X 320 GB
Ultra X4 750 watt fully modular
Thermaltake Overseer RX 1 full tower
Core-Contact 92 mm CPU Cooler
Logitech G510
Razor DeathAdder
50/5 Mbps UL/DL
Optical: Super Muliti DVD burner w/lightscribe, Hauppauge WinTV HVR-1800
already checked but still the same..still got sound only on my left earphone..how to determine whether my jack is broken or not?
1366 x 768 Pixels
e-view
NETWORK CARD
Try plugging in another set of speakers/headphones that you know are in working order.
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
already do that before..and all the headphone that connected to my jack,all of them got no sound on right earphone..but still i'm not satisfied with that..i'm still thinking that my jack is still in good condition,bcause if it really broken it will not produce any output to headphone..i still thinking i missconfigured something..am i right?
1366 x 768 Pixels
e-view
NETWORK CARD
If you look at the jack stud on the headset there are two grooves one is for the left and the other is for the right. The same thing on the receiving end of the input. Those grooves are what makes the connection. They can and do go bad from time to time, either the left or right side or both sides. If you have used a known good head set and it is doing the exact same thing you have now how confirmed it's a bad input jack. Sounds cards are fairly cheap and as an add on card they are very easy to install. My suggestion is to replace the sound card with an add on PCI card and your problem is solved. To repair the jack itself is possible but would cost more in the long run then it's worth but it can be done. That is if your up to soldering and knowledgeable of the techniques involved. Best of luck.
Custom built
On board RealTek HD
1600 X 900
Logitech G510
Razor DeathAdder
50/5 Mbps UL/DL
Hello Mie333,
To adjust the balance, go to Control Panel>Sound and right-click on Headphones. Hit Properties, and under the Levels tab, you will find Balance.
~JK
Windows 7 Professional x64Intel i7 2600K OC'd @ 4620 MHz16GB GSkill Sniper 2133 Mhz (4x4GB)EVGA GeForce GTX 480 SuperClocked+
Asus P8Z68-V Pro
2x Acer S273HLbmii 27"
2 x 1920x1080
64GB Crucial M4 SSD
Storage: Hitachi 1TB 5400RPM, Samsung 1.5TB 5400RPM
Corsair HW Series 750w (modular)
Cooler Master HAF 932 Advanced Blue Edition
CM Hyper 212+ CPU cooler, 3x 230mm + 1x 140mm case fans
Logitech MK320 (wireless)
30 Mb/s : 2 Mb/s
I had problems with those Nvidia Geforce 4 drivers on my old PC with Windows 7. The headphone jack worked perfect in XP but no luck with Windows 7.
Windows 7 64-bitAMD Athlon II X4 620 Propus @ 2.6ghzOCZ Platinum 4GB (2 x 2GB) 240-Pin DDR2 SDRAM...ATI Radeon HD 4200 [on board]
Windows 7 64-bit
GIGABYTE GA-MA785GM-US2H
OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2
Realtek ALC889A [on board]
APEVIA X-QPACK-NW-BK/420 Black Aluminum
Hello Mie333,
~JK
oh..jk..i go to cntrol panel -sound but i dont find headphones..it just have speaker and dgtal output..but there is no icon headphone..but still,i can hear from the left side of my earphone
1366 x 768 Pixels
e-view
NETWORK CARD
Go ahead and click on Speakers, rather than headphones. I should have anticipated that in my last post. :o
Asus P8Z68-V Pro
2 x 1920x1080
64GB Crucial M4 SSD
30 Mb/s : 2 Mb/s
k i do all what u told me..n i set the left n right both 100..but still just have one sound on my left side :confused:
1366 x 768 Pixels
e-view
NETWORK CARD
Have you tried a System Restore to a point before the trouble started?
Asus P8Z68-V Pro
2 x 1920x1080
64GB Crucial M4 SSD
30 Mb/s : 2 Mb/s
With the above, you can goto DM, disable the audio device, restart and re-enable it if it doesnt automatically and check. Stil not fixed?
Goto DM again, uninstall, restart and once the card gets detected, allows windows to select the right drivers and check.
If u dnt hv a driver CD with u, pls dont try the last method.
Lioni54GBIntel
MacBook Pro
Lion
i5
4GB
Intel
1200x800
Seagate FreeAgent GO 250GB Ext. HDD
already done..but still no luck :(
1366 x 768 Pixels
e-view
NETWORK CARD
1366 x 768 Pixels
e-view
NETWORK CARD
