Center/sub Not working.Help Me pls.
sritcs
1:05 AM
Hi,Its a well known problem.Am not getting Surround sound.only 4 speakers work.I use on board card only.Center and sub woofer are not working.I installed latest driver.I activated 5.1 in my audio controller program(Intel Audio studio).Will "WINDOWS 7 SUPPORT 5.1 FOR MY BOARD"?My specification as follows,
Operating System : windows 7 ultimate.
Mother Board : Intel D945 GCL.
Audio drvier : IDT
(Will post the exact version of my driver later).
Speaker : creative 5.1 inspire.
If u need any more details ,i would furnish u soon..Please I need 5.1 to work well and charm in my windows 7.Thanks in advance.bye.
windows 7
windows 7
Does the full speaker system work OK when you test the speakers in the Control Panel - Hardware and Sound - Sound Panel? That is also where you setup what type of speaker system, e.g. 5.1 that you have.
It worked OK on my Intel M/B with the Intel IDT drivers (when I tried the IDT audio, before installing a separate sound card). I have Win 7 64 bit OS.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
I have tried all the setting .both in intel audio studio and in control panel sound setting.Speakers are fine worked well in xp 3.and i installed driver which actually suport vista.because for my board there is no driver for windows 7...
windows 7
windows 7
Please some one help to get surround sound on my system.If i switch to streo (2.1) i get surround.but i need that in 5.1 ...help experts..
windows 7
windows 7
One issue, if your motherboard does not support Vista, it could be a compatibility issue and you may never get it working with the IDT drivers. Ultimately you are probably going to have to install a separate sound card that is Win 7 compatible to get it working. This is not unusual for older hardware that does not have Win 7 support. I see this a lot on the Dell users forum from users that have older Dell's that are not supported in Vista or Windows 7, users are installing new sound cards to get full sound compatibility.
My system, that I noted in my original post, is Vista and Win 7 compatible so there were no issues.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
