Keep losing right audio
  1. Posts : 4
    I keep losing the right audio then after a while it comes back. Have Windows 7 no special audio just two speakers plugged into motherboard. Any ideas?
    Check the speaker connections, both at the PC end and at the speaker end. A plug that is not fully inserted or making a poor contact can cause the problem you are having. Try unplugging the connection to the PC and then plug back in - do this several times to "clean" the contact. Same way at the speaker end (if the cable has a plug).
  3. Posts : 3,822
    gotta be the wiring or the connection..
    maybe you've got some duff cable..
  4. Posts : 4
    Will do...will report back.....don't think it's an internal problem at the moment as the socket at the front of my machine for headphones seems to be working fine.
