Windows 7: Keep losing right audio
18 Feb 2010   #1
PaulPaul
I keep losing the right audio then after a while it comes back. Have Windows 7 no special audio just two speakers plugged into motherboard. Any ideas?
18 Feb 2010   #2
fireberd
Check the speaker connections, both at the PC end and at the speaker end. A plug that is not fully inserted or making a poor contact can cause the problem you are having. Try unplugging the connection to the PC and then plug back in - do this several times to "clean" the contact. Same way at the speaker end (if the cable has a plug).
18 Feb 2010   #3
BugMeister
gotta be the wiring or the connection..
maybe you've got some duff cable..
21 Feb 2010   #4
PaulPaul
Will do...will report back.....don't think it's an internal problem at the moment as the socket at the front of my machine for headphones seems to be working fine.
Losing NAS shares
Hi I run a couple of NASs on my network holding media files. One of them has recently started losing some, but not all of it's shares on the network and the actual device is not showing up in Network. To keep it simple, I have three shares M for music, S for shared files and V for videos. I...
Network & Sharing
Losing HDD space !
So...I'm losing HDD space,without any reason. I have *NO* system restore points ( don't know why ),I just scanned my PC for any viruses,but nope. Literally,as you are reading,im down to 25 GB of free space... Help please ? :C
Performance & Maintenance
How can I migrate to a new pc without losing everything?
Basically years back I got an HP desktop that came with Windows 7 installed. Basically I want to stick my hard drive into a new computer and dump the old crap. Problem is I'm pretty sure that won't work either because the copy of windows is tied to the motherboard that I no longer have use for or...
Installation & Setup
Windows 7 losing audio driver after waking from sleep...
I recently installed Windows 7 Professional 64 bit on a machine utilising an Asus M4N82 Deluxe motherboard. I subsequently installed all current drivers for use with Win7 64 bit for the Mobo downloaded from the Asus website. Windows 7 itself found current drivers for the peripherals that it...
Drivers
How to decrease audio quality without losing channels.?
Hi to all seven forums. hope all will be fine. guys I extracted an audio from a mkv movie using mkv merge gui, and this is the audio status. . Complete name : The Green Hornet 2011 1080p BRRip.mkv Format : Matroska File size :...
Losing CD-ROM drive
I have a new Acer Aspire 4810T that came with Vista. I have done the upgrade to Windows 7 and now when I insert a disk into the CD-ROM drive,or just close the drive the drive disappears from Device Manager as I watch! Also, I sometimes need to use a paperclip to open the drive. When it was running...
Hardware & Devices
