Volume level keeps resetting to 30%
Grinch80
9:10 PM
I'm at the end of my rope with my volume issue. I'm running Win 7 64 Pro with a Creative X-FI Gamer card (latest drivers).
The issue: Master volume keeps resetting to 30%. Noticed it happens when I bring my PC out of standby, and when I run certain apps like Creative's sound panel. I've tried the "Do Nothing" option on the Comms tab, and also tried unchecking the Exclusive Mode options which give apps direct control over the sound card. Nothing works.
Is there a way to set the master volume in the registry and/or create a task which runs periodically to adjust the volume to where I want it? Any other ideas?
Thanks.
Windows 7 Pro (64-bit)Intel Q6600 @ 3.4Corsair Dominator TWIN2X4096-8500C5DF (2x2GB)XFX Radeon 4980
Intel Q6600 @ 3.4
ASUS P5Q-Deluxe (1406)
XFX Radeon 4980
Creative X-FI XtreamGamer
ASUS VW224U LCD
OCZ Vertex 2 120GB (v1.23), WD Raptor 150GB & Caviar Black 1TB, Seagate FreeAgent 500GB (external)
PCP&C 750w
Antec 1200
TRUE+Scythe SFF21F
30 down / 8 up
This is usually a function of a corrupted driver or some other application "taking over" the sound card's volume control. However, I've seen this problem on some older Dell's with SoundBlaster sound cards and that turned out to be a BIOS problem. Clearing the BIOS fixed the old Dell PC problem.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
All my drivers + BIOS are up to date. Anyone else experiencing this problem?
Intel Q6600 @ 3.4
XFX Radeon 4980
ASUS VW224U LCD
PCP&C 750w
Antec 1200
TRUE+Scythe SFF21F
30 down / 8 up
I am having the same issue (volume spontaneously resetting to 30%) and have the same sound card. For me it will reset every few minutes. I've been running win7 for a month or so, but the problem only started in the past few days.
Anyone had luck resolving this problem?
Windows 7 64bitAMD Athlon 64 X2 3800+2 GBnVidia 8800gtx
HomeMade
Windows 7 64bit
asus a8n32-sli deluxe
2 GB
nVidia 8800gtx
soundblaster x-fi gamer
dell 24"
1920x1200
7200rpm sata 80GB
600watt
antec
thermaltake big ass copper jobby
microsoft with extra buttons
logitech mx700
12mbit
Good point!
A few years ago, Real Audio would do this, it was always installed as a task bar "tray" applet and would sometimes change the soundcard's volume to it's master volume setting.
Also, if your audio card has it's own dedicated mixer it's possible the Microsoft mixer is not reflecting the same settings and resets the volume.
Look for any process running in the background that could affect audio.
Ap
Windows 7 Home PremiumIntel Core 2 Duo @ 3.00gHz4 GBATI Radeon HD 2600 XT
Assembled in my workshop
Gigabyte GA-P35-S3G
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
just registered to revive this... more than two years later, i'm having the same issue. creative x-fi here as well (Creative SoundBlaster X-Fi Titanium Fatal1ty Professional), so it's definitely creative's fault. just wanted to let you know. still looking for a solution though - open for suggestions ;)
Windows 7 Professional x64
Alright, just registered to revive this once again! I have a solution that has worked for me in the past.
Make sure your volume is at 100% (or whatever fixed level you want it at) and open your Creative Console Launcher (doesn't matter which mode, whatever you use) and go to "Settings". Click on the "Encoder" tab. Check the box to Enable Dolby Digital Live. Any sound or video playing might glitch out a little when you do this. Uncheck the box and voila, the volume level should now stay locked coming out of sleep or on a reboot. It may start reverting to 30% again if you switch between Creative Console Modes a few times, but I stay in Game Mode 100% of the time so it has not been an issue for me!
Hope this helps someone in this thread!
Windows 7 Home PremiumIntel(R) Core(TM) i7-2600K CPU @ 3.40GHzCorsair XMS3 16 GB RAM (4 X 4GB)GeForce GTX 780 Ti 3GB
ASUS P8Z68-V LX
Seagate Barracuda 1 TB
WD Black 3 TB
Webroot
