PCI simple communication + Front jack Problems
hello, before i installed my windows 7, i was running on windows xp(SP3) but yesterday I had installed windows 7 and all i got to say is it's Fantastic compared to windows xp. except I had kind of ran into couple problems, such as after i had used "Driver Genius pro edition" + "unknown Device" and gotten all of the proper drivers for my new OS, every thing works fine except for PCI simple communication controller not beening able to install, I have a feeling that this is also the reason why my 3.5mm front mic jack doesn't work. My mic use to work with Windows xp, now... not so much
Specs:
MoBo: Intel ~ DP965LT
Intel Dual Core2 CPU (1.86 GHz x 2 so 3.6GHz)
Ram 4GB DDR 2
500gb of Hard Drive
Video card ~ Radeon x1600 (going to be upgraded soon )
Microphone : 3.5mm Speaker/mic Jacks. Front and Back
I have been tried all kinds of driver's and stuff.. they are either incompadiable with OS windows 7 or MoBo. The I can't seem to manage to fix this problem, so any help is very appreciated
