Windows 7: Need help with audio display
19 Feb 2010   #1
iSasquatchh
I use an HP dv7 model laptop and when I turn the volume up or down, a little audio meter pops up to show me the current sound level. My problem is, when gaming it will minimize the game and often times crash it.
Does anyone know of a way to disable it from popping up?
Thanks!
19 Feb 2010   #2
Frostmourne
Windows 7 Ultimate x86-64
HP's software - look for a control panel to disable the option, or uninstall the utility.
19 Feb 2010   #3
iSasquatchh
I still can't seem to find out how to do this...
Do you have any more details for me?
19 Feb 2010   #4
Frostmourne
Quote   Quote: Originally Posted by iSasquatchh View Post
Look in the control panel for anything HP, then type its name into the start menu and press enter. Configure.
19 Feb 2010   #5
Aphelion
Windows 7 Home Premium
A down and dirty method.
Right click on the task bar, select "Start Task Manager".
Go to the Processes tab.
Look for any HP related processes, you will probably find more than one... pick the most likely, unless an obvious choice is apparent you may have to go one at a time. Choose one and select the "End Process" button. Check after each process you stop and see if the volume pop-up is gone.
The problem is... it could be under a different name as part of the audio device software.
As Frostmourne posted... there may be an HP or audio configuration utility lurking around.
If you do find process that's causing the pop-up, there's a couple of methods to prevent it form loading at statup.
Ap
p.s. If you deselect the "Show Processes From All Users" checkbox there might be more HP background processes visible.
20 Feb 2010   #6
iSasquatchh
Quote   Quote: Originally Posted by Aphelion View Post
Ap
Hey thanks a lot! The first process I ended just happened to be the right one.
It's called "audiodg.exe" for future reference.
20 Feb 2010   #7
Aphelion
Audiodg is part of the Windows 7 audio and effects processing engine for Windows 7, I don't think audio/sound will work without it.
Perhaps that's why you no longer see the pop-up!
So, that's probably not going to be a permanent fix as it should reappear when you start to play audio.
Ap
Realtek High Definition Audio and Intel Display Audio
I think my question is this: how do I set up VSX-1124 (a Pioneer AVR) in Control Panel/Sound and Hardware/Sound so that its driver is Realtek HD Audio and not the Intel Display Audio one? In Device Manager under Sound, Video and game controllers, I have two sound card drivers, Realtek High...
WMC plays TV audio, but no video display (black screen)
Hello, I hope this is not a repeat question as I have checked and searched the forum thoroughly. I have a problem playing live TV using Windows Media Player. I can select different TV channels without a problem. I can hear the audio clearly. However, i can not watch anything as it displays a...
Media Center
Disabled HDMI audio in sound drivers, but also lost visual display!
I usually have my computer connected to my LG TV via HDMI cable, recently I tried disabling the sound from my LG TV, so it just played through my computer speakers, however when I disabled the HDMI driver in the sound driver menu, I also lost visual display. I reconnected my computer through VGA,...
Hardware & Devices
Would like to automate some processes - change audio output/display
Hi all, I've been hunting around, but, basically, I don't know exactly what to even search for. Here's my setup: I have my PC hooked up to a standard monitor and computer speakers. I also have a digital audio out running to my receiver and a VGA hooked up to my LCD TV. Whenever I want to throw...
General Discussion
No audio on 2nd display
I have a Dell 8100, GTS 240 video card that has sound through DVI (2 DVI connections). One DVI to Dell 23" monitor, other DVI/HDMI to Panasonic TV. When playing a DVD with "PowerDVD", the video and sound are great on both my computer screen and my TV. Realtek audio. When I stream something...
