Windows 7 IDT Audio 5.1 Sound Problem.
  1. Posts : 14
    Windows 7 PRO x64
    Hi guys . 1 day ago i had a problem with my IDT audio on windows 7 . I couldn't set 5.1 option in the IDT Control Panel the setting jumped back to Stero options. I changed windows , changed alot of stuffs. I tried another way posted here that said to set 5.1 in windows control panel , this soultion was odd because in winamp was 5.1 but was a bad bad sound , no bass and with echo. I have to mention that in windows TEST all speakers sounds good , but music/video/apps/game.. ... This morning i found the best solution for everyone who's been in the situation. I found some drivers, that they rlly work , and you can change to 5.1 in IDT control Panel. I tested the drivers on Windows 7 Ultimate x32&x64 and i'm curently using them in Windows 7 Pro x64. I hope that everyone who had this problem, this driver will resolve . Cheers.
    PS: My audio was IDT on a dp35dp Intel mboard
    Drivers here :
    MEGAUPLOAD - The leading online storage and file delivery service
  2. Posts : 1
    Google Traduction
    Thanks: D
    It's not perfect but it works better than others.
  3. Posts : 14
    Windows 7 PRO x64
    Well,if you or anyone alse can find a better one,i would be glad to install :P
  4. Posts : 44
    windows Seven 7100
    Is this the same driver for the DELL Studio Laptops?
  5. Posts : 1
    Windows 7 Professional 64-bit
    Sigmatel STAC9271D on-board audio AC97 IDT driver
    Thank you cristi2k!
    This worked like a champ on my Intel Desktop Board DG965WH and Logitech 5.1 surround sound set. I downloaded it from your link at MEGAUPLOAD too.
  6. Posts : 8,135
    I have an Intel DP35DP motherboard. I'm not using the SigmaTel (now called IDT) sound as I have a separate sound card installed. But the IDT drivers on the Intel site for this motherboard worked for me when I did use them.
